Results 1 to 10 of 12
Thread: single cab conversions
    Feb 2025
    south australia
    hello all,
    will a 110 sinlge cab go on a 90 td5 chassis always been a dream of mine and does anyone know where i can source a cab from without having to buy a entire ute would considr it if cheap enough and would like to not have to deal with rust as already working on a wb kingswood any info appreciated
    cheers.
    Jun 2013
    Universe A
    Quote Originally Posted by kennedy07 View Post
    hello all,
    cheers.
    This would be better posted in the defender section.
    Have you got a complete 90 TD5? If so I'd just convert that.
    Feb 2025
    south australia
    Quote Originally Posted by shack View Post
    Cheers I’ll ask over there and hoping to buy a gal chassis and put 110 cab on it with flat gray
    NE Victoria
    32.83 MB
    Are you thinking of a truck cab, or a cab chassis?
    If truck cab, it's a factory configuration, so shouldn't be hard, if you can find the parts, as truck cabs are rare in Aus
    If cab chassis, the body would be doable using the rear bulkhead from a 130, but the mounts for the body and a tray probably aren't on the chassis.
    If your planning on starting with a new chassis, I suspect you'll never get it registered, as it will be considered a 2025 build, and will need to comply with current regulations.
    Your first port of call needs to be your state registration authority and an engineer.
    Tony
    Aug 2011
    Stanwell Park, NSW
    666.1 KB
    i'm half heartly got a 110 single cab (cab chassis) 300 tdi for sale. has a crack in chassis and some minor rust in rear cross member and a cracked head that has caused me to pause on the restoration. it's in rough shape being a former farm ute, but perfect to pick off what you want and sell off the balance. Being a 110 cab chassis, it will give you the roof and back glass but afaik the rear bulkhead will be different to a 90 truck cab. You could potentially cut out the bulkhead from the 110 and fit it internally to the 90 panels to replicate the 90 truck cab. PM me if you are interested to talk.
    MLD
    Current: (Diggy) MY10 D130 ute, locked F&R, air suspension and rolling on 35's.
    Current: (but in need of TLC) 200tdi 110 ute & a 300tdi 110 ute.
    Current: (Steed) MY11 Audi RS5 phantom black (the daily driver)
    Gone: (Dorothy) MY99 TD5 D110
    Feb 2025
    south australia
    Quote Originally Posted by TonyC View Post
    Tony
    Cheers mate was going to go with a new gal chassis and it would have to be engineered anyway for the lift and other mods I want to do what do you mean a 2025 build what if the cab was part of a registered Ute then I was just doing a “chassis swap”
    Feb 2025
    south australia
    If I was to convert it where would I source the rear bulkhead from
    Feb 2025
    south australia
    Tony
    And yes truck cab
    Feb 2025
    south australia
    Quote Originally Posted by MLD View Post
    Hey mate If you could shoot me a message that would be awesome still figuring out how to use this page
    NE Victoria
    32.83 MB
    If you just put an old chassis number on the new chassis, you are "rebirthing" and old car this is illegal.
    You need to to talk to your registration authority as to how you go about a chassis swap, I suspect it's different in each state.
    If you are doing mods that will need engineering, then talk to your engineer before you start, to ensure what your doing is engineer able.
    Good luck with the project.
    Tony
