Thread: Overheating but why?
    VladTepes's Avatar
    Bracken Ridge, Qld
    I'm out and about and noticed my temps on my 300tdi defender up touching the red.
    Plenty of coolant in the overflow reservoir.
    Any ideas?
    I'd go to MR Auto but they are closed on weejendw6
    gone
    1993 Defender 110 ute "Doris"
    1996 Discovery 1
    current
    VladTepes's Avatar
    Bracken Ridge, Qld
    Oh and fluid in reservoir is hot so there's presumably circulation happening.
    Mar 2012
    Armstrong Creek, Qld
    Dodgy radiator cap, perhaps? Try loosening it a little, when cooled.
    'sit bonum tempora volvunt'
    Jan 2010
    I'd check that it is not a worn water pump or fan that's not moving water or air.
    2005 D3 TDV6 Present
    1999 D2 TD5 Gone
    VladTepes's Avatar
    Bracken Ridge, Qld
    Seems to be fluctuating again. Will drove home carefully and look into it. I'm suspecting fan at the moment.
    gone
    1996 Discovery 1
    current
    Sep 2010
    The Hills.
    152.79 MB
    Quote Originally Posted by VladTepes View Post
    Oh. I was going to suggest thermostat.
    So, along with the other suggestions, partially blocked radiator, collapsed hose(s), or of course the dreaded head gasket.
    Also, is it actually hot? I mean are there overheating symptoms other than the gauge? iOS, could it be electrical?
    ​JayTee
    Nullus Anxietus
    Cancer is gender blind.
    2000 D2 TD5 Auto: Tins
    1994 D1 300TDi Manual: Dave
    1980 SIII Petrol Tray: Doris
    OKApotamus #74
    Nanocom, D2 TD5 only.
    Torres Straits
    Hate to say it
    But from above info it’s head gasket till proven otherwise
    The normalised gauge doesn’t move till your up over 100
    The red is pretty much 125 from memory
    Of course feel free to change all the other bits
    Or just muck in a knock the head off doesn’t take long
