Thread: Sump Gasket
    May 2009
    Tatura, Vic
    Sump Gasket
    Having removed my sump I was toying with the idea of using a silicone sealant instead of a gasket.
    Permatex "Right Stuff" looks like it would work
    My only concern doing this is the clearance required between engine and sump, due to sump also bolting to the transmission bell housing.
    Anyone done it?
    Permatex Right Stuff 90 Minute Gasket Maker Black 85g - PX25228 | Permatex | Shop our Full Range by Brand at Autobarn | Autobarn Category | Autobarn
    Dave.
    I was asked " Is it ignorance or apathy?" I replied "I don't know and I don't care."
    1983 RR gone (wish I kept it)
    1996 TDI ES.
    2003 TD5 HSE
    1987 Isuzu County
    May 2009
    Tatura, Vic
    I did try this. I elongated the 4 holes in the bell housing. I filled it with oil and have run it with no leaks.
    Still on my hoist as I have other things that need doing.
    Before I filled it I went to tighten the sump plug and guess what, it just tore out the thread.
    So off to the nut and bolt shop for a $125 helicoil kit.
    I will report back after 6 months to see if it leaks, but I am confident that if it is not leaking from the start it will last.
    This is what I used
    Dave.
    1996 TDI ES.
    2003 TD5 HSE
    1987 Isuzu County
    Sep 2010
    The Hills.
    152.79 MB
    Just saw this. I had an indie take my sump off to check the oil pump bolt. He used RTV on it and it’s been fine. Rear main, not so much
    ​JayTee
    Nullus Anxietus
    Cancer is gender blind.
    2000 D2 TD5 Auto: Tins
    1994 D1 300TDi Manual: Dave
    1980 SIII Petrol Tray: Doris
    OKApotamus #74
    Nanocom, D2 TD5 only.
    May 2009
    Tatura, Vic
    Quote Originally Posted by Tins View Post
    Did they just use it on its own without a gasket? If so, due to the sump now being a tad closer to the engine, the 4 bolts that come through from the bell housing wont line up.
    I had to elongate the holes.
    Dave.
    1996 TDI ES.
    2003 TD5 HSE
    1987 Isuzu County
    Sep 2010
    The Hills.
    152.79 MB
    Quote Originally Posted by d2dave View Post
    Good question. I don't know for sure.
    ​JayTee
    Nullus Anxietus
    OKApotamus #74
