Results 1 to 3 of 3
Thread: Confused USB
    May 2003
    On The Road
    Confused USB
    All of a sudden, every time I plug my phone into the laptop by USB I have to TELL windows what I want the USB cable to do, charge, transfer data, etc
    All I ever want it to do is transfer files but its DEFAULT is charge...
    yes its an uptodate win 11....
    St Helena,Melbourne
    4.28 MB
    1st world problem hey, wars in the world but you have to click a button
    2004 Jayco Freedom tin tent
    1998 Triumph Daytona T595
    1974 VW Kombi bus
    1958 Holden FC special sedan
    Is it Windows asking you to choose or is it Android asking you to choose? BTW I thought the default action was always 'charge', ie no data transfer to take place until enabled in some manner.
    If Android, then among the options which control what happens when USB is plugged to the PC are (at least on my version of Android 13)
    1) Settings->Connected devices ->USB -> Show pop-up to choose the desired mode (charging only if turned off)... Toggle on /off as required. In your case I assume you want it 'off' to suppress the pop up asking what you want to do on plugging your phone into your PC.
    2) Settings->Connected devices ->USB -> Use USB for... Select default purpose as required. In your case I assume you want 'File transfer'
    If Windows (at least in Win 10) then it may be controlled by the options under 'Autoplay' for your specific phone.
    Setting -> Devices -> AutoPlay... chose your device (ie your phone, which you should see listed) and select from the drop down menu what action you want. In your case I assume you want 'Open device to view files (file Explorer)'
    2024 RRS on the road
    2011 D4 3.0 in the drive way
    1999 D2 V8, in heaven
    1984 RRC, in hell
