Thread: Disco, relocation of ignition system for dual battery
    Upwey, VIC
    My disco use to have a dual battery setup which worked well just for my engel overnight, but I wanted something that would last longer, so I have started moving the ignition system and aftermarket cruise control to where the old battery was, so I will have the room to put a BIGGER deep cycle battery.
    Old Setup :
    New Setup :
    As you can see I have removed the old, smaller battery and relocated the ignition coil/amplifier also had to move the aftermarket cruise control.
    Just wondering how I should move the power steering bottle ? just a longer bracket ?
    Also should I make up a splash guard so the ignition system doesn't get wet ?
    Once I have moved the power steering bottle and tidyed up some of the wiring, I'll go get a bigger deep cycle battery.
    Will post pics once I have done that.
    Matt.
    May 2002
    Sydney, Australia
    Quote Originally Posted by matbor
    Yup - just cut the bracket from the mounting and extend the bit in the middle.
    HTH
    LRH
    Disco 4 SDV6 Auto
    Disco 4 SDV8 Dual Cab Project
    Disco 2 M57 Extra Cab Project
    Foton Tunland Cummins ISF
    Disco 1 3 door 4.6 V8 Auto
    RRC V8 Auto "Classic" Softdash
    RRC 300 TDI Auto
    Disco 1 TD5 Auto Buggy
    Disco 1 300 Tdi Auto Ute
    SAME Explorer 70HP 4x4 Tractor plus Nell Loader
    Subaru GDA WRX
    Triumph Bonneville SE
    Yamaha TTR250
    Quote Originally Posted by matbor View Post
    Matt.
    Bump. Well you've had a year and I would like to see how you've moved the power steering (I wanna do it myself)
    Post up then
    one of the discos I did that to was just a case of fabricating 3 l bracket and then riveting them together to from a re-inforced piece of angle ally that I then drilled to suit the exisiting resivior. I then moved the resivior around untill I found some place that kept the hoses out of trouble pop marked the wheel guard drilled it then bolted it down.
    Feeling lazy?
    ARB does a bracket ready made to move the PS bottle out of the way....
    Quote Originally Posted by Tombie2 View Post
    Feeling lazy?
    Sounds very tempting but I'm just wanting to see where they've actually been moved too. I'm due for some new ps hoses so I want to relocate the reservoir and if needed fab up different length hoses to suite the new spot.
    I don't mind fabbing up my own brackets, but I just want to see what others have done to fit the extra battery in. Coils the easy part, just the reservoir is a little more involved.
    Upwey, VIC
    Totally forgot about this
    I relocated the PS, but never brought a bigger battery because the one I had was still working. Will be buying one in the next 6 months though as the current one is on its way out atm.
    The bracket I just made longer using a bit of scrap metal and a couple of bolts and also cross braced it. It has been like that for a couple of years now and have had no problems.
    Some pics that i had on my computer, if u need better ones let me know.
    Matt.
