Thread: TD5 Intercooler pipe question
    Melbourne VIC - Australia's largest Nanny State. Thanks Brumby!
    Hi all,
    For all those with Disco TD5's, a question re the intecooler hoses.
    From the outlet of the turbo, you have a short rubber pipe, which feeds into a 40cm or so metal pipe, then feeds into another rubber hose before going into the intercooler.
    My question is regarding the 40cm metal pipe that both rubber hoses connect to.
    It would appear that part of the pipe has been pressed, ie a depression in part of the pipe by the factory and not by damage. This would introduce surely a airspeed reduction and therefore affect lag and other things.
    Do all TD5's have this metal pipe with this depression?
    Chris
    Douglas Park, NSW
    Quote Originally Posted by cwebb View Post
    Chris
    All the pipes that I've seen go through my warranty room are the same.
    NSW SW Slopes
    Its required to provide clearance to the ACE pump and pipe. Mine sits very close.
    Pennant Hills, Sydney
    mine had that but I cut that bit out and replaced it with a short bit of exhaust tube still clears the banjo fitting on the ace pump
    disco seriesII mods so far:-bullbar,hyd winch,
    detriot locker,lsd front,C.D.L kit,chipped and bigger intercooler,2" lift,rock sliders, lsd in transfer case, modified auto trans.
    In the event of nuclear war,Disregard this message
    tombraider Guest
    Quote Originally Posted by stevo View Post
    I hope you used Stainless!
    The benefits of this are negligible, its a closed area running forced induction...
    No major difference will be felt, the transition into the IC will produce more turbulence
