Thread: TD5 Coolant Change
    Kingaroy Qld
    TD5 Coolant Change
    Hi all,
    Im preping my TD5 for a coolant change and I was all a quandry as to what would be best to used.Many offered their explanation out here in Kingaroy, and was left a little perplexed.Cant trust these bush mechanics.So rang BOR and MR and both suggested tottally different products and both streets apart.
    1 suggested concentrate
    the othe suggested premixed.
    So I went out and made up my own mind and bought "Tectaloy" Xtra Cool Gold concentrate.Makes up to 15 litres.
    It was the choice of two auto shops and the were the only two who seemed to colaborate.
    Could you guys help with your professional opinion.
    David Kemp
    S11 TD5
    S1 97 V8
    S111 SWB 74
    May 2003
    On The Road
    try here David,,
    http://www.aulro.com/afvb/showthread.php't=34329
    if you are still concerned,, keep asking!!
    Kingaroy Qld
    Thanks for the Tip.I would have spat the dummy if I had stuffed it
    David
    Williams West Aust
    Hi David
    I dont think that Tectolly is any good for the TD5,I normally use that brand in any vehicle Ive had,it didnt seem to say O.A.T when I changed my coolant.Its very important you get the O.A.T style coolant,usually a red colour.
    Very important to thoroughly flush all exsisting coolant out before adding new.
    Assuming you have good water,concentrate is the go as you cannot remove all the coolant out of a TD5,also the reason for PLENTY of flushing needed.
    Supercrap sell a concentrate,NULON RED LONGLIFE,about $25 for 2.5lts,you need 2 bottles.Better to overdose than underdose.
    Andrew
    DISCOVERY IS TO BE DISOWNED
    Snow White MY14 TDV6 D4
    SYDNEY -in the shire.....
    Hi David
    Andrew
    or you can get it in 5 litres for $45......
    why give them the extra $5 for the same thing......?
