Results 1 to 10 of 19
Thread: 110/Defender metal radiator grilles
    Apr 2007
    Sydney city
    My plastic grille is brittle, cracked and starting to drop bits. Has anyone had any experience with any of the metal radiator grilles?
    I'm wondering if there's any airflow issues in our warmer climate.
    Kyabram, VIC 3620
    Can't really see the first two properly, but the last one certainly has enough 'free area' to allow sufficient air through.
    Serious answer why not go get a BBQ grill for it, that way it will be duel purpose like the original grills.
    Singapore via Melbourne
    mine is similar... very brittle...
    but I need one for a county (sits about 30-50mm forward of the headlights)
    where is the first one from? haven't seen it before
    Apr 2007
    Sydney city
    Thanks for the replies.
    An eBay search for a replacement grille came up with the third one.
    Searching the web for other grilles turned up the first two, both appearing on British army Defenders.
    http://www.operations.mod.uk/veritas...d_wmik1_hr.jpg (2000x1414 pixels)
    The first one is seen on WMIKs
    http://www.adrianstomcat.co.uk/WMIK.htm
    I might look into fashioning something barbequeable.
    I think I have some of those in the recycled bits bin, will check tonight...
    NSW far north coast
    mines made up with 1" square weldmesh.
    It's in two pieces, hinged at the bottom so that it can sandwich air conditioning filter media in it
    I can't claim credit for it, although I have modified it for better condenser fan clearance.
    I'll see if I can get a photo today.
    Toowoomba, Queensland
    Quote Originally Posted by EchiDna View Post
    Mighty Monotreme,
    I replaced my broken County one with one off a Defender - the extension forward has the same opening in it as a Defender, and as a Stage 1 for that matter.
    Steve
    2003 Discovery 2a
    In better care:
    1992 Defender
    1963 Series IIa Ambulance
    1977 Series III Ex-Army
    1988 County V8
    1981 V8 Series 3 "Stage 1"
    REMLR No. 215
    or you could pimp your Defender with a Bling Grille,
    google LRX grille for suppliers (ABS Plastic though)
    Brisbane, Queensland (Australia)
    Quote Originally Posted by dobbo View Post
    ........ and removable front seat bases to put on top of two jerry cans for a seat ..... and then drop the rear tail gate for a table. Landys used to be so multi-purpose .
