Results 1 to 10 of 13
Thread: Urgent Help Needed Please??
    Hamilton,Vic
    Im replacing all the bearings on the pullys system and Im in the middle the job now, but I need help......
    Ive done the two bearings on the ac side of things , but I cant get that stupid circlip out of the main alt belt tenisoner pully!
    Its not the normal type, ie no holes but the ends are angled back, so whats the best way to attack it?
    Looking forward to hearing from you soon
    _________________
    Apr 2002
    Godwin Beach 4511
    32.43 MB
    Quote Originally Posted by amshaw View Post
    _________________
    i use a small screwdriver to lever it out, well 2 actually......
    2007 Discovery 3 SE7 TDV6 2.7
    2012 SZ Territory TX 2.7 TDCi
    Hamilton,Vic
    Ok thanks, is better to put pully in a vice so no movement?
    If it is really stuck, use a pin punch and a small hammer and tap one of the angled bits inwards, then get a screwdriver in there
    Hamilton,Vic
    still pushing poo up hill.........
    Keilor East, Victoria
    this style of circlip gave me greif in my hilux days on the front axles.
    Circlip pliers + Swearing + small screwdriver to lever once the circlip pliers opened it up a little was the best method i found...
    Steve
    ...then the screwdriver slips and you have a hole in your hand.
    Been there, done that with the blasted Disco idler.
    Then, when I was reassembling it with the new bearing, the screwdriver slipped again and badly dented the bearing shield. So I had to get another bearing.
    Ron
    Avoca Beach
    I saw a site in Seth Efrica once where the guy cut a space/slot in the rim of the pulley . He machined it, but a Dremel would be OK with a HD cutting wheel. You can cut the circlip, then replace it with a conventional one.
    Regards Philip A
    St Helena,Melbourne
    4.28 MB
    A pair of small long nose pliers work well, if you dont have a spare or replacement circlip/spring clip, make sure you put a rag around it so you dont lose it.
    2004 Jayco Freedom tin tent
    1998 Triumph Daytona T595
    1974 VW Kombi bus
    1958 Holden FC special sedan
    Apr 2002
    Godwin Beach 4511
    32.43 MB
    Ron
    you twist the screwdriver not lever it out.. to start with
    after you twist and it starts to move you lever it a little with the second one enough to lift it a little, then work your way around...
