Where's the turbo? High-mounted turbo bolted to exhaust manifold = 200Tdi. Low mounted turbo integrally cast with exhaust manifold = 300tdi.
Stupid Q, but I have to ask, as someone has made me question what i thought I was positive about
My 95 fender Dcab130, 200tdi or 300tdi?![]()
Ian &
Leo - SIII 109/GMH3.3
Daphne I - '97 Disco 300Tdi Manual
Daphne II - '03 Disco Td5 Auto
I thought the 200tdi was only till 1994 ??
1994 Discovery TDi
2004 Discovery 2 TD5
2010 Discovery 4 TDV6
2004 Jayco Freedom tin tent
1998 Triumph Daytona T595
1974 VW Kombi bus
1958 Holden FC special sedan
'95 should be 300 Tdi. If the thermostat housing has two cast "circles" in the top it is a 200 Tdi, smooth top is 300 Tdi.
You mean I actually have to DO SOMETHING do find out
I thoght it would be a simple Q![]()
should be a 300 Tdi - easy visual check Passenger side air intake or snorkel 200Tdi / Drivers side intake 300 Tdi
HTH
LRH
Disco 4 SDV6 Auto
Disco 4 SDV8 Dual Cab Project
Disco 2 M57 Extra Cab Project
Foton Tunland Cummins ISF
Disco 1 3 door 4.6 V8 Auto
RRC V8 Auto "Classic" Softdash
RRC 300 TDI Auto
Disco 1 TD5 Auto Buggy
Disco 1 300 Tdi Auto Ute
SAME Explorer 70HP 4x4 Tractor plus Nell Loader
Subaru GDA WRX
Triumph Bonneville SE
Yamaha TTR250
Dont know if defenders are the same but I normally just look at the belts on Disco's, serpantine belt=300, V belts=200.
I dont know if this is a good meathod but Ive only had to work it out once on a built in 93, regoed 95 Disco that a mate bought pre update heap of crap (I dont mean all that model are, just his).
It had had nearly no maintenance over the years and was falling appart but he thought it was the ducks guts.
I didn't get a chance yesterday to check turbo position and thermo cap, but the snorkle is drivers side, suggesting it's a 300, as i always thought. Can anyone else confirm the snorkel location test? I hadn't heard that one.![]()
yep, air cleaner is on the drivers side on a 300Tdi 'fender, passengers side on a 200. Engine is hard up against the firewall on a 200 with a long fan shroud, engine sits much further forward on a 300Tdi.
