Thread: lifespan?
    May 2003
    On The Road
    lifespan?
    Just wondering about the lifespan of an external HDD,, does it vary much from the usual HDD's?
    also,,, while your all here--
    why does my USB HUB (12month old D-Link) show up as a SLOW usb connection?
    Apr 2002
    Bellara 4507
    32.43 MB
    depends on the brand and the vendors specs to the manufacturer, esp if it is branded.
    most prepacks they order oem grade which is 1 year.
    me, i wont sell prepacks, had way to much trouble with them.
    me, i only sell external cases with a power switch on them and seagate drives as they have 5 year warranty and 1/3 the death rate of the western digital drives. i simply wont sell the other brands as they have crap mtbf's IME.
    your milage may vary....
    2007 Discovery 3 SE7 TDV6 2.7
    2012 SZ Territory TX 2.7 TDCi
    It might help that they are external and so might not have to run as hot
     2005 Defender 110 
    May 2003
    On The Road
    thats the funny thing,,
    I have two 8cm fans on the internal,,
    makes a big difference,
    but the samsung runs quite warm to the touch,,
    maybe not hot, but its not far off.
    hmm,
    wheres that hated price list,,,
    Brisbane, north of the river
    Actually when I was looking for my external HDD one of the biggest rates of failure was overheating.
    The case does have a fan in the back but the HDD still doesn't have the airflow that it does sitting inside my PC.
    Quote Originally Posted by incisor View Post
    seagate drives as they have 5 year warranty and 1/3 the death rate of the western digital drives. i simply wont sell the other brands as they have crap mtbf's IME.....
    My desktop PC is vibrating. I have to pull the tower case covers off and disable the cooling fans (;eaving the HDD as the only rotational source) to be certain. If it is, I may be calling you - it's the Seagate I bought from you.
    Ron
    Regarding the USB Hub, the device may only be USB 1.1. Otherwise try plugging it into a different USB port that you know is USB 2.0 FULL SPEED (if you have them on your motherboard).
    As far as I am aware if you have a USB Hub that runs at USB 2.0 FULL SPEED it should have an external power supply attached.
    Apr 2002
    Bellara 4507
    32.43 MB
    Ron
    not had one do that, but there is always the first one...
    might be quicker for you if you organise it on their website, tho am happy to do it if needed...
    May 2003
    On The Road
    Regarding the USB Hub, the device may only be USB 1.1. Otherwise try plugging it into a different USB port that you know is USB 2.0 FULL SPEED (if you have them on your motherboard). CHECK!
    CHECK!
    You'd want to read this-
    http://www.dansdata.com/gz055.htm
    and maybe this-
    http://www.dansdata.com/gz060.htm
    Simon
