Results 1 to 6 of 6
Thread: 8 blade oil cooler fan
    Cape Town
    I noted in the past that my Series III oil cooler still has a 4 blade fan and assumed my heating problems on very hot days is a result of the wrong fan.
    I checked with our local Landy supplier and found in his parts book the upghrade to 8 blade together with the oil cooler incldes changing the three pulleys (Water, crank and Alternator) I assume to speed up the fan itself and probably also the water pump.
    Unfortunately seems like these part numbers are no longer available in RSA.
    Do any of you have experience of the 8 blade fan for the 2,25 P engine oil cooler?
    Any advice would be welcome.
    James
    Defender Kalahari 2006 (300 TDi)
    2008 Puma 110 - sold
    1973 Ser III 109" - sold
    The eight bladed fan is an option, and normally comes with double belts (hence the new pulleys). If fitting one it is a good idea to also fit the tie bar between the flywheel housing and the cross member to minimise the chance of the fan hitting the radiator.
    If the rest of the cooling system is in good shape, the eight bladed fan should only be needed for stationary or very slow use (same for the oil cooler), even in very hot conditions.
    Cape Town
    slow use
    I only have the problem of overheating up a long slow mountain pass when there is not a breeze and 30'C plus
    I did also mount and electric fan in front of the cooler/radiator but even though it cuts in it makes little difference and the temp just keeps climbing. The oil temp actually gets hooter than the water temp and when I shut down the engine to allow the oil to cool off the radiator starts to boil over.
    By the way, the radiator is brand new, pump is 100% and I cleaned out the oil cooler inside with mild acid clean a few years back when overhauling the motor.
    I am going to have to post in the UK to see if I can get the correct fan blades and pulleys.
    James
    Quote Originally Posted by CapeLandy View Post
    James
    It is possible that in the circumstances could allow overheating, but a few of points -
    1. The electric fan probably gives as much extra cooling as the eight bladed fan.
    2. When working hard, oil will normally be hotter than the coolant
    3. When you stop to cool off, the engine should be allowed to idle (even a fast idle) rather than shutting it off, to keep the coolant and water circulating and the air circulating through the radiator.
    4. I would be looking for additional causes for overheating, such as manifold air leaks, ignition timing and dragging brakes.
    Cape Town
    thanks
    Thanks Mate
    I did try idle like you said but the oil temp kept climbing above the 100'C so I had to shut down. Seems the only way the oil temp drops quickly is an engine switched off.
    I suppose it is better to boil the water a bit than burn the oil
    I have checked all the other items and am at a total loss. I even acid cleaned the sub assembly with an acid bath and pacifying after to make sure there was no gunk in the water passages.
    The only thing I am a little suspiciose of is the oil pressure. It runs at 6,5 bar at quite a few revs. The oil cooler system has a different spring specified for the oil pump but I noticed before overhauling my motor that the oil pressure was very low. So when I took out the oil pump I noticed that someone had left out the small ball bearing below the poppet and spring and this brought up the pressure all be it quite a lot. Better too high than too low I guess. At idle the pressure is normally at 1,5 to 2 Bar when hot but 6,5 bar at 80 km/h.
    I am not too concerned as it is only at extreme ambient and hill climb that gets her really hot, so I just chill for 20 minutes and carry on.
    Thanks anyways.
    James
    Thanks Mate
    James
    The oil will stand a lot more than 100C - in a standard installation without an oil cooler (or oil temp. gauge), it would probably normally be around that or higher when working. I remember when I discussed adding an oil temperature gauge to the Gipsy Major in the Auster I used to own the mechanic discouraged me - "I've added them before but had to take them out because they frighten the pilot". Maybe this is your problem?
    Remember that aircooled engines rarely run as low as 100C, and use the same oils.
