Thread: 130 rims
    YEPPOON QLD.
    130 rims
    Gday all. I'm needing another tdi 130 rim. Are these rims different to 110 defender rims in width and offset ? What other landrover models have the same offset and width ? Am thinking a set of alloy wheels might be in order .
    NSW far north coast
    they are indeed unique in the Land Rover world, being 6.5" wide and a 20.6mm offset (a wider offset than other landy rims) witha higher load rating than a 110 rim.
    East-South-East Girt-By-Sea
    1.20 MB
    Quote Originally Posted by rick130 View Post
    6.5" X 16 rims with a 936Kg/wheel rating have been on Land Rovers since the early 1960's.
    The only difference with the Def 130 rims will be the off-set, or in fact rim inset. The Series 2B being the most out set.
    Can someone with a Def 130 tell me the part numbers of the 130 rims?
    Diana
    Ferntree Gully VIC
    i can measure my standard rim in the morning for you ............... 2000 TD5 130rim
    130's rule
    NSW far north coast
    Diana
    I stand corrected.
    I always forget the FC's
    BTW, the HD Wolf style (holey) 130 rims are ANR5593 (tubed) and ANR4583 (Tubeless)
    1.20 MB
    I stand corrected.
    BTW, the HD Wolf style (holey) 130 rims are ANR5593 (tubed) and ANR4583 (Ttbeless)
    Thanks I will update the database and perhaps redo the pic.
    BTW the 1 ton Land Rovers are the ones that most Aussies don't know. To my knowledge there was only ever one imported and it was a Rover Factory prototype.
    Would love to get my hands on it if it still exists!
    Diana
    YEPPOON QLD.
    LOTS-A-LANDIES just had a look at my tdi 130 rims part No. on rim is ANR1534. Good info you posted before , great work.
