Results 1 to 10 of 12
Thread: Feeding cable from the engine bay to the tow hitch area.
    Sydney, NSW (nr Epping)
    Hi All,
    I have bought one of the Traxide SC80-LR units & want to install some HD cables from the region of the aux. battery (in the engine bay) to near the tow hitch (so that I can also charge a battery located in the caravan).
    On my D1, I did this by removing the A pillar trim & running the cables up there & then "chasing" them between the roof & the roof-lining. Now, with the air bags on the D3, I don't think I can do that.
    Any "sensible" advice appreciated.
    Best Wishes,
    Ive almost always done that by first of all routing a bit of pull through string into a length of garden hose then threading the garden hose along the inboard side of the chassis if not inside the chassis itself then pulled the main power cables through after zip tying the hose in place.
    Normanhurst, NSW
    I've found the yellow 'tongue' from particle board flooring handy for poking through hard to get at places - stiff enough dut still flexible enough to do the job.
    Roger
    Hi Blknight,
    So you're the bugger who keeps stealing garden hoses. And here's me blaming people making bongs.
    Last edited by Bushwanderer; 7th December 2007 at 08:45 AM. Reason: correcting typo
    Quote Originally Posted by Xtreme View Post
    Thanks Roger,
    I have some "yellow tongue" for exactly that purpose, but am concerned about the airbags in the A pillar.
    Melbourne, Australia
    Hi Bushwander,
    See my reply on Disco3.co.uk to your post.
    I did this very job this week on my D3 but used the LHS chassis rail rather than the RHS one but the left or right should be similar.
    Chris
    Had to do a similar thing when I first got my D3. The goose who'd installed the anti rust system had cable tied the chassis wire along the length of the LH chassis beam (or whatever it is you call it) and of course it got snagged on my first outing.
    I found a hole in the beam near the engine bay and feed the wire to the rear end inside the beam, then out again.
    Hi All,
    There seems to be a consensus forming here.
    1. Feed the cable through the chassis rail, &
    2. Either LHS or RHS rail should be OK, although slightly more seemed to have used the LHS rail.
    I will probably use the LHS rail myself, as (at Drivesafe's suggestion), I could set up a suitable junction for take-offs for 12V outlets in the rear of the D3.
    Perth, WA
    Quote Originally Posted by Bushwanderer View Post
    Hi All,
    Just wondering if you did this, and if you have any pics? I have the exact same job to do this weekend!
    Jeff
    1994 300TDi Defender
    2010 TDV8 RRS
    Nov 2007
    Trailer Accessories plug
    Watch this space I'll do a step by step install with photos this weekend if my SC80-LR arrives in time.
