Thread: 300Tdi brake servo
    Jan 2008
    300Tdi brake servo
    On a Automatic '96 disco. It's hissing (softly), and a new one is $500! Any other way out? Brakes are fine otherwise, but I'm getting tired of the reaction I get when asked about it, and I respond "don't worry about it - it's just the brakes."
    St Helena,Melbourne
    4.28 MB
    Is it the servo or the vac pump ?
    2004 Jayco Freedom tin tent
    1998 Triumph Daytona T595
    1974 VW Kombi bus
    1958 Holden FC special sedan
    Jan 2008
    Servo
    St Helena,Melbourne
    4.28 MB
    Where is the hissing coming from ? if it is leaking it usually means the diaphram has split, not sure about disco ones but i had a leak in my old rangies servo so i pulled it apart, cleaned and re assembled it and its still good after 13 years.
    1974 VW Kombi bus
    Jan 2008
    It's coming from where the pedal attaches. It doesn't look servicable, and the manual indicates it is not servicable, but I thought I would ask. Do they commonly go bad? Is a second hand unit an option?
