Results 1 to 10 of 20
Thread: TD5 Fuel Filter Replacement Interval
    Dandenongs, Victoria
    I know this has probably been brought up before but I had a search and couldn't find how often the Fuel filters on Disco 2 TD5's should be changed?
    DougLD Guest
    Hi Robbo
    My copy of Rave states every 40000klms but I replace ours every 20000klms
    Doug
    same, check it every 10, replace it every 20 but Im getting a good deal on filters so I dont mind so much.
    South Yundreup,WA.
    LR every 40,000kms but I do ours every 20,000kms to be safe.
    Dave (Blinknight) let us in on the cheap filter supplier.
    2011 Discovery 4 TDV6
    2009 DRZ400E Suzuki
    2003 WK Holden Statesman
    Departed
    98 Ducati 900SS Gone & Missed
    Facta Non Verba
    four wheel drives down in melbourne, I purchase the full kit from them their catalog, its about the cheapest IVe seen all 4 filters in one go.
    NSW SW Slopes
    How do you check that the TD5 fuel filter needs changing? Surely not just because there's water in the drain?
    South Yundreup,WA.
    Ta, already use them.
    2009 DRZ400E Suzuki
    Departed
    Facta Non Verba
    South Yundreup,WA.
    You can not really check it apart from water, the only way to check it is to cut it open.
    2009 DRZ400E Suzuki
    Departed
    Facta Non Verba
    yeah I do the water drain thing every 10
    Same here.
    Drain at 10, change at 20.
    Too easy
