Thread: 1999 defender extreme
    Jan 2008
    I have two problems that I need advice on-
    1. I replaced the two rear brake pads about six weeks ago, and absent-mindedly threw out the pieces of thin metal that were on the back of the existing brake pads (I believe they are called squeal plates). They were fine for 4 weeks but now the new brake pads are making some deep squealing noises. Is this because i did not put the pieces of metal on the new pads? If so, can you buy just those pieces of metal by themselves?
    2. Starting to find it tough to get the defender into reverse, and fourth gears mainly, what should I be looking at first? Is the clutch going? It certainly seems to be clunking and grating a bit more when trying to get it into gear sometimes.
    Thanks for your time and help, Jamie Luck
    Christchurch NZ
    1. Anti-squeal shims, probably a dealer only item.
    2. Check the clutch hydraulics, sounds like the clutch is dragging, or too little oil or too thick an oil in the gearbox.
    1995 Defender 110 300TDI :D
    1954 86" Series 1 Automatic :eek:
    Ex '66 109" flat deck, '82 109" 3 door, '89 110 CSW V8, '74 Range Rover, '66 88" soft top, '78 88" soft top, '95 Disco ES V8, '88 Surf, '90 Surf, '84 V8 Surf, '91 Vitara.
    Feb 2005
    Quote Originally Posted by jamieluck View Post
    was about to do the same myself till i asked my parts supplier when i picked up a caliper kit half way through the job.....had dig them ut of the bin
    i sure you can buy them seperate
    May 2002
    Sydney, Australia
    which pads did you install?
    I have heard of problems with none Genuine pads squealing - to the point it can give the same impression as the ABS sensor is failing, as it can produce the same frequency to the sensor!!!
    HTH
    LRH
    Disco 4 SDV6 Auto
    Disco 4 SDV8 Dual Cab Project
    Disco 2 M57 Extra Cab Project
    Foton Tunland Cummins ISF
    Disco 1 3 door 4.6 V8 Auto
    RRC V8 Auto "Classic" Softdash
    RRC 300 TDI Auto
    Disco 1 TD5 Auto Buggy
    Disco 1 300 Tdi Auto Ute
    SAME Explorer 70HP 4x4 Tractor plus Nell Loader
    Subaru GDA WRX
    Triumph Bonneville SE
    Yamaha TTR250
    There is some anti-squeal goo you can buy that you put on the back of the pads where the caliper pistons push on them - the pads would need to come back out. The goo is designed to absorb and dampen the vibrations that cause the squealing.
