Results 1 to 10 of 23
Thread: td5 manual vs auto that is the question
    Highlands NSW
    So finances might be better now and I might be looking at a td5 sooner than thought. What re pros/cons auto vs manual in the td5? My old 300tdi was a dog at take ofs but ok once going... Can a manual be chipped for better performance?
    2010 110 Crew Cab Deefa
    Mittagong NSW 2575
    99.87 MB
    If you want better control, especially when 4WDing and sheer driving pleasure... then an auto.
    If you anticipate break downs and the need for clutch starting... then a manual.
    Slunnie
    Gold Coast, Qld
    I drive a manual TD5 D2 and love the control a manual offers but really, the TD5 engine is better suited to the auto box. Yes you can chip either auto or manual and they perform much better but really it boils down to personal choice. I will always drive manuals off road but as Slunnie says, for more control off road the auto is the go.....and in sand etc.
    Do a search though as there are a few threads on this very subject with lots of opinions and experiences.
    Aye, Mick
    '99 Manual TD5 D2.......heap of money spent on it and it has ended
    Mar 2007
    South Arm, Tasmania
    And just from another perspective - compared to a lot of other vehicles, the clutch pedal in a TD5 manual is quite a long "throw" and is fairly heavy.
    It doesn't bother me, but SWMBO hates it (good thing really - she generally leaves it alone).
    I'm comparing to Prado manual petrol and diesel, plus many conventional cars.
    Cheers .........
    BMKAL
    Douglas Park, NSW
    Auto all the way with the Td5. The engine is more suited to the auto IMO (the opposite of the 300Tdi).
    Bear in mind though that the auto can't cope with the power developed by some Td5 chips & will go into limp mode. The milder chips aren't a problem.
    Jul 2007
    Two Rocks, W.A.
    Well I never wanted an auto 4wd, ever....till I drove a mate's GU in the sand and had a re-think. The car I chose I picked because of everything else that was going for it - just happened to be an auto.
    With a 140kw chip I've not had a problem with the trans yet...maybe I haven't booted it hard enough!
    Only thing that bugs me a little is the lag on take off which on some occasions seems worse than others - just easier to build the revs in the manual prior to take off. Love the auto in the peak hour traffic though, but after 6 months I did miss changing gears, hence the arrival of the Wrangler.
    '00 D2 Td5 'Alice'
    '03 V6 Freelander 'Phoebe'
    '04 Td4 Freelander 'Harry'
    Kingston, Tassie, OZ.
    My opinion, If I was to get a Td5 D2, it would definately be auto. I would also try and get something after 2001, as the auto's can deal with more torque/ chipping etc. '03 onwards is the go, better auto trans software, able to take more torque(400+Nm) without limp mode, and a much nicer shift pattern/ feel.
    The manuals, as has already been stated by a few, are busy to drive, and the clutch is heaps heavier than the 300Tdi model.
    Auto all the way with these, better with the later models.
    Enjoy.
    JC
    Jun 2008
    Milton, Queensland
    Moving from a 300Tdi to a Td5 i did notice a stiffer clutch pedal, but i figured that the pedal can be pressed with much greater ease if only it could be bend slightly upwards. So i heated the pedal slightly and bent it upwards, and hit feels a lot lighter as you can press it with your leg now instead of just your foot.
    ACT
    I love my manual, but I was just lucky that one came up in my local area at the time I was looking to buy...the issue is that you'll have much greater choice in which D2 you buy if you're looking for auto as the manuals are relatively rare c.f. D1s...
    Always looking for creative new ways to get bogged... :whistling:
    76 RR...sold coz fuel was expensive at 70c/l :eek:
    93 200 Tdi Disco...old faithful...sold to make way for...
    99 Td5 Disco ACE...nice drive...hopefully reliable...
    Karratha WA
    Thumbs up Auto
    For towing, definitely the auto.
    ToombRaider ECU remap, remove EGR, close wastegate right up with engine off, Fit vortex muffler.. What Lag off idle?
    BradM
