26th March 2008, 07:30 PM
Rear tyre wear on 130 Tray back.
Hi
Rotated the tyres around about 6mths ago, as the fronts were just starting to wear on the inside edge a bit, just noticed today they are still wearing the same way on the back
, i would have thought on the rear they would even out across the tyre?, have i got something else going on?
Cheers Sumo
26th March 2008, 09:53 PM
from my experience, once a wear pattern develops it will continue even if put on the rear. I think it helps slow it down but you need to fix the front problem.
blaze
26th March 2008, 10:34 PM
Mine do the same and the alignment is OK. It's a combination of (in my case) MT tyre, toe out and a driving/steering axle.
You'll have to pull them off the rim and swap to the other side to beat the wear and keep them rolling the same way, which is what i do.
26th March 2008, 10:39 PM
#4
What pressure are you running I always had mine above 45psi and had no problem
Adam
27th March 2008, 05:09 AM
#5
Had something similar on my 110. Ended up having to change the bearings in one of the front swivels as they had collapsed.
HTH
M
27th March 2008, 06:12 AM
#6
Usually running between 45- 50 psi.
