Results 1 to 10 of 17
Thread: The new LROV90
    Geelong
    The new LROV90
    Just though I would add a few pictures of my new 110's tranformation. Only the basics done at this stage but will add more when I get time.
    So far fitted:
    -Cruise Control
    -Ipod deck
    -Bullbar / winch / lights
    -Bash guard
    -New front and rear suspension.
    Free Again Thanks Dan
    Nice has the new defender gone back to the salsbury rear diff , and how much for that bling diff cover
    Padstow NSW
    Quote Originally Posted by rangieman View Post
    differant driveway=differant 110.
    cheers phil
    I'd Rather Push My Land Rover in QLD Than Drive A Toyota in NSW
    Quote Originally Posted by discowhite View Post
    cheers phil
    That or the rear X member rusts quicker than ever
    Sydney, NSW
    Thats once seriously clean underside and nice looking 110.
    Out of interest how much lift have you given it with those new springs and dampers? Im assuming its quite a bit with the cracked rear trailing arms and dislocation cones.
    Are you on standard damper lengths of increased?
    Regards,
    Jon
    Mar 2007
    perth western australia
    That diff cover looks like an ARB jobby if Im not mistaken
    yackandandah, vic
    Quote Originally Posted by LROV90 View Post
    So far fitted:
    -Cruise Control
    What cruise control did you fit?
    Geelong
    Sorry the ARB diff is on my brothers 00 110. Its was $290 from arb but it is for a dana 60 (same pattern) so sometimes ARB get confused if you ask for one for a landrover.
    The cruise is from an aussie mob called Autron which you should be able to google. It was $750 fitted.
    The lift is about 2 1/2 inches - using OME springs with spacers and 80series front shocks and GU rears on the back.
    The front driveshaft shook like a helicopter, so the DC shaft out of the 90 is going in. Only hassle is it has to be made 65mm longer!
    Quote Originally Posted by Yorkshire_Jon View Post
    And they stay like that for years when one doesn't have salt on the roads!
    Ron
    Sandstone Point Qld
    Gday mate,
    Just want to pick your brains a little about the suspension setup you have.
    Iam looking to do a simalar setup to mine just so I know what your talking about the DC shaft means "Double Cardan" ?If so why didnt you put a Double Cardan on your exsisting front shaft?
    Also did you do anything about your castor like Haultech bushes or custom radius arms?Last thing your rear suspension picture I can see kinked rear trailing arms just wondering if you bought them or customized them yourself?
    Sorry for so many questions mate but Iam trying to do as much research as possible before doing any mods and seeing what other peoples have done.
    Cheers Azza
    P.s Awesome Defender .....
