Results 1 to 9 of 9
Thread: LR In Car DVD problems
    Toowoomba
    G'day All,
    Have had the D2 for a week and a bit now and one of the buying points was it had an in car DVD player, Land Rover though think it is Eurovox. Any disc I put in shows up Loading for a little while and then says "Invalid Disc". I took it back to the yard I bought it from and they had a fiddle....no result....thought it maybe need a clean. So went and bought a disk cleaner this morning, popped it in....again "Invalid Disc" , so wouldnt even play the disc. Tried some other dvd's to no avail. Kids are giving me grief over it, anyone have a clue as to what the problem maybe before I take it to the likes of Strathfields or something...thanks,
    Stevo
    Is this the unit that sits under the passanger's seat and accessed from the back seat floor area?
    Just checked the manual for mine, no error codes or fault tree in the booklet.
    Are you using a bought Region 4 DVD? If not I'd try that first in stread of a recorded one.
    Toowoomba
    Yep thats the one, under the passenger seat. Im just trying your normal DVD ie that you buy from the shops or get from a video shop,
    Stevo
    Two Rocks WA
    Stevo will it play a normal not burnt or recorded by you audio disc ok?
    Does it recognize that it is a audio cd or does it still say not recognized?
    if it plays the audio cd ok then maybe the laser is dirty.
    If still comes up saying cant recognize disc then I would say laser.
    try putting in the disc so u know excatly where any of the writing is and when it comes up and says cant recognise eject it to see if it is still in the same spot. What I am trying to see is if the disc is actually spinning. If its not spinning then the spindle motor is crap and will need replacing, this too was common.
    Let me know what u find
    Brad
    Range Rovers Have Charactors inside them
    LROCWA Ex member 23 years
    1971 Series 2A
    2004 Discovery2a V8 Auto
    2003 Discovery2a TD5 Manual
    1982 4door man (sadly now gone)
    1989 Vogue auto
    2011 TDV8 Vogue
    What would life be without a Rangie?
    Toowoomba
    Brad
    Thanks mate, I will have a look and report back. At this stage it doesnt matter what DVD you put in it, it just comes up with Invalid Disc. I bought a cleaning DVD and same thing.If it is the spindle motor is that exxy to replace?
    Stevo
    Dalby
    If it is the spindle motor I have had luck before in removing them and shooting a bit of lanolin or light oil in the motor and spinning it by hand.
    This revives some of them.
    Quote Originally Posted by stevo68 View Post
    Stevo
    Warranty??? All cars have 3 months from a dealer.
     2005 Defender 110 
    Toowoomba
    Apparently not covered under the warranty, even checked out Fair Trading
    Stevo
    Island
    Stevo
    I discovered this too when I bought the V8. Didn't even turn the radio on, as I was busy listening for important noises. Bought the car, got it home, turned the radio on and nothing. It was a completely different unit, the plugs didn't even match up. Oh well, fitted my own. Felt like a DH briefly tho.
