Thread: 91 rangie
    classic Guest
    91 rangie
    something let go in the drive line the other day i suspected the tranfercase just climbing a steep road underload and bang !! no warning no drive in any gears hi or low.still at a mates place havent taken the drain plug out to look at the oil yet i herd thiers a slip joint between the auto and the transfercase and they can go or mabe a broken chain either way not good thanks chris::
    99.87 MB
    did you try locking the centre diff? I've heard of axles/diffs breaking on the road while driving.
    Slunnie
    classic Guest
    1991's has a viscous coupling with just a high and low ratio.
    thanks anyway
    chris
    Hi,
    Splines in torque converter failing. Slunnie this is relevant to what you are doing.
    I'm DL on the OL forum.
    cheers.
    Two Rocks WA
    Hello Chris it will more than likely be the transfer case shaft between the rear output and front output behind the viscus
    have a look at this http://www.aulro.com/afvb/technical-...case-pics.html
    and
    95 classic drive train
    I did mine before it went Bang as It is a common problem with high k Rangies mine had done 360k and was ready to go bang.
    they are very easy to dismantle and repair.
    Brad
    Range Rovers Have Charactors inside them
    LROCWA Ex member 23 years
    1971 Series 2A
    2004 Discovery2a V8 Auto
    2003 Discovery2a TD5 Manual
    1982 4door man (sadly now gone)
    1989 Vogue auto
    2011 TDV8 Vogue
    What would life be without a Rangie?
