Results 1 to 10 of 31
Thread: VM Diesel
    East-South-East Girt-By-Sea
    1.20 MB
    VM Diesel
    Just a question about the VM diesel once used in the Range Rover.
    We hear all the banter anout all the different diesels the old Land Rover 2 1/4 diesels the 200Tdi, 300Td1 Td5, 4BD1, 4BD1-T, TdV6, TdV8 and even Detroit 3-53 and GMC jobs.
    What I don't think I have ever seen are any threads on the italian VM.
    Were they that bad or do then no longer exist having past their use by date?
    Diana
    I'm no expert on them, however I remember reading that they were derived from a boat motor and had 4 separate heads, one for each cylinder. I think jeep also used them. They reportedly suffered cronic head problems and were not as reliable as the Tdi's that replaced them after only a couple of years.
    St Helena,Melbourne
    4.28 MB
    Quote Originally Posted by Taz View Post
    Correct ,more trouble than they are worth. Apparently the jeep VM's were an improved version and 2.5 ltr instead of 2.4.
    2004 Jayco Freedom tin tent
    1998 Triumph Daytona T595
    1974 VW Kombi bus
    1958 Holden FC special sedan
    Yinnar South, Vic
    Have a search, there has been a couple of threads asking about them, the answers lie within
    Brisbane, Inner East.
    Don't go there. Motore cane.
    URSUSMAJOR
    1.20 MB
    Quote Originally Posted by Brian Hjelm View Post
    Brian
    Didn't even hazard a thought in that direction, t'was just that they were fitted as OEM and no one ever mentions them. I guess that would explain a lot to the less moronic than me!
    Diana
    Free Again Thanks Dan
    Brian
    Diana
    Dont ever think about it please
    Douglas Park, NSW
    All the trouble seems to be with the 2.4 VM that was sold here in the Range Rover. I started at JRA in 1989 & saw quite a few problems with the 2.4.
    However, JRA had imported a 2.5 VM Range Rover. Either that or it was fitted locally. It was supposed to be here for evaluation but I have never heard of the 2.5 being sold in the UK.
    This car was driven hard during it's time at JRA & performed faultlessly. The performance gain over the 2.4 was immense so it may have had a different turbo.
    I'm sure it was still around when JRA folded in 1991 so there is at least one good VM fitted to a Range Rover somewhere.
    I wonder where it is now......
    RonMcGr Guest
    Diana
    Introduced in 1986 - 1994
    ENGINE
    Manufactured by VM DIESEL of Italy. 2392 cc, 4 cylinder, borexstroke-92x90 mm
    OHV, 2 valves per cylinder, compression ratio 22:1
    Indirect injection with KKK - K3 turbo charger with intercooler. Boost pressure 12.0 psi.
    Max. power: 112 bhp @ 4200 rpm
    Max. torque : 183 lb.ft. @ 2400 rpm
    TRANSMISSION
    5 speed manual
    4 speed auto box optional
    PERFORMANCE(with 5 speeder)
    max speed: 93 mph@ 3700 rpm
    0-60 mph: 16.5 sec
    weight: 4440 lbs
    fuel cons: 21.4 mpg
    The VM Diesel Specialist
    C838 WWK Camel Trophy Range Rover
    Pictures of the engine:
    ETC9091N 2.4L 4 CYL VM DIESEL ENGINE ASSY | Range Rover Classic 1986-1991: Major Units | shop | www.lrseries.com | L. R. Series
    Canberra, Australia
    My RR originally had a VM, now replaced with Tdi300.....
    still got the old motor, it had been doing a grand job running a 3" water pump, until the pump gave up..... so good for VM spares
    While I was running the motor in RR (2 years) I found the following Yahoo group had a number of expert members:
    VM-dieselengine-group : VM diesel engine group
    Michael T
    2011 L322 Range Rover 4.4 TDV8 Vogue
    Aussie '88 RR Tdi300 (+lpg), Auto (RIP ... now body removed after A pillar, chassis extension to 130 & fire tender tray.)
