Post or pre turbo, wheres the EGT sensor located?
post turbo generally about 650deg C is the outside limit and you dont want to hang around there for long but you can push 600 all day if you need to but you wont be doing your fuel economy any favors.
pre turbo will dpend on how effecient your particular turbo is. ITs always hotter pre turbo by anything from 20-200 degrees depending on how much gas flow your getting and how much back pressure your system generates.
Id tip not wanting to be over 750 pre turbo.
the softening point for the hardening of the TD5 is around the 1000 degree mark Im not sure about the tdi's but I cant imagine it being much different. Remeber thats the temp inside the combustion chamber while its still going bang and not whats turning up at the exhaust.
1000 degrees on your exhaust is probabley a very very bad thing.
