Q.
I don't know what manufacturer make/model/weight this will take. Any pointers on where this may be located?
I don't have the towball bit at all so the above will help me to know what it is so I can get one. I've uploaded a pic, that may make it easier. Perhaps by first glance some of you may know already what make/manufacture it is? Otherwise, happy to go clambering under the rear to find info :-)
Hayman Reece tongue will fit, MAX weight over the ball or downward pressure is 250KG and max weight you can tow is 3.500KG.
Towbar Wiring
I've always been use to seeing the older round wiring bit that you plug the trailer etc in2, however this one is marked with '7' in a circle and the text LUMEN underneath, with the plug end of the wiring being rectangular etc.
Q.
Any ideas where one can purchase the wiring bit that plugs into the towbar>trailer etc? How much do they normally retail for? Can you pick them up from a wreckers or would it be best to buy new? It it a particular make I need to ask for? Male>female connectore here. I have absolutely no idea!
A; Any trailer place, auto supplier, Supercheap and so on, just ask for the female trailer plug.
Q. Any pointers on a excellent strength adhesive so I can glue together the plastic seal that is a little split? (This is on the LHS top where the plastic seal starts to go around the bootdoor - again not sure of the terminology here)
A; Super glue
Repair / servicing / maintenance manual
My D2 is a - DISCOVERY II 00.5MY 2000. Any pointers on where one can obtain a repair manual from so hubby/I can do any repair / servicing / maintenance work etc? Any pointers on what's the best one to buy out there and how much they go for? Also, would this manual include operation of all the buttons on the dash! I have no idea what some of them do or how to engage them to work!!
Rave CD from the Markets section of this forum.
Some Vic members can answer the rest
Spare Parts
I have a few things I would like get. Any pointers or links to purchase these items, either second hand/new or any wreckers in Melbourne that specialise in Landrover parts?
1. LHS rear tail light that has a small broken piece missing from the bottom RHS corner. Is the rear taillight one piece or is it 2 pieces?
2. Side steps - any ideas what ones are good, not fussed whethr they are silver in colour or black. Not sure if they came with standard ones as aftermarket product? Is there any special holes to factor in when fitting, any brands etc you could recommend?
3. On the LHS where you have the plastic moulding that curves around the rear side panel that sits ontop of the bumperstep looks like it's missing one clip that it clips into so it sits flush against the panel. Not sure what you call it, but is there a specific clip/screw etc that I need to ask for?
4. On the inside, I think I am missing the panel that sits on the console at the bottom, maybe it is meant to have a picture of the gears and how they work when in 4wd mode?
Airbag Modules Replacement
I have in the service portfolio/owner info booklet a replacement date for the airbag modules. Any ideas on how much something like this would cost and is it mandatory to get them replaced?
Cheers Baz.
2007 BMW R1200GS
