Results 1 to 10 of 11
Thread: Disco V8i Not Starting
    Victoria, Geelong
    Exclamation Disco V8i Not Starting
    Went to start the beast today and it won't kick over all I hear is a clack from the engine bay I noticed the same problem a few days ago but the next attempt it dod start but now it just won't.
    Any idea what the problem could be ???
    stuck solenoid on the startermotor.
    Victoria, Geelong
    Sounds like it is not that close to that area.
    PS. I am not happy my avatar has been removed just because I am a Regular member.
    which area is it coming from. it could be the aux start relay (forgot what they call it in a LR) that drives the solenoid....
    Theres a couple of other relays that need to be doing there thing for a start so it could be as simple as your starter solenoid is not getting power/singal and you can now hear the normal relays dropping in..
    Victoria, Geelong
    Sounds like it is coming from the front of the engine bayon the left side passanger side.
    Blairgowrie, Vic
    Check the battery charge, battery earths, earth straps to engine, and stop snivels before they hurt!
    Good luck on the hunt for the problem. I think the starter relay is behind the rh kick panel, but a check on RAVE 1 will show where it really is!
    HTH
    Pete
    Dizzie, 08 D3 TDV6 SE
    Victoria, Geelong
    Sorry for the delay on this but it turns out to be the starter motor. The bushes on the motor are wearing out I can start the landy again but at times it won't start so I am wondering how much a reco or new starter motor will set me back.
    Jun 2008
    Just had the same problem, Jag & Rover spares in Brissy has magnetti marelles for $385, bosch supercheap option was about the same
    Colac foot of the otways
    Jun 2008
    Only thing to keep in mind buying second hand, these are a high torque motor and can be burned out easily, They do not handle been cranked for too long and are not able to be rebuilt, I have been caught out before buying one of these 2nd hand and it died soon after,
    I am not totally throwing the 2nd hand idea out but check it out well
