Hi all.
Does anyone know if the split bush (modified - s111?) will fit a std s11A (suffix F) gearbox?. I have found some mentions of the split bush on other threads, but can't find the answer to the above.
Also in need of a clutch throwout fork and a radiator support panel (late 11a type - headlights in guards).
Thanks for any info.
Andy
Thanks for ypour response isuzurover
I understood that the split bush was a mod to prevent the splitting of the original bush.
I could not work out how the second part of the bush is prevented from spinning with the gear, but having not seen one as yet there may be a simple answer. Is the one piece stronger or are there other issues with the split bush?
Andy.
Exactly, that is the problem, it isn't!!! And if I remember correctly, there are splines under it, rather than a smooth shaft.
I rebuilt my gearbox about 6 years ago using a new, one-piece bush. I have had to pull it apart a few times since (broke 1st gear, etc). The bush was still in 1 piece last I looked.
