Results 1 to 10 of 21
Thread: 300 Tdi - Bit More Go
    Jock The Rock Guest
    gday
    i was just wondering i have a 300 tdi which has done 280000 ks. i was just wondering could anyone suggest how to get a bit more go out of the old girl. nothing to expensive and hopefully something that wont compromise fuel economy.
    i have just done a rear main seal so wont be able to afford anything for a while.
    what would you fellas suggest?
    Thanks for ur help
    Jock Hamilton
    Not a huge amount you can do really.
    Wind out the fuel pump and change the intercooler (but they cost a bit) There are also VNT turbo conversions available but they cost even more!
    Pete.
    along with winding out the fuel pump you can mess with the boost pressure setting a little bit by adjusting the wastegate valve rod and then a little tweak on the boost compensator (part of the FIP) will bring it up a little faster.
    NSW , Pennant Hills
    Quote Originally Posted by Jock The Rock View Post
    gday
    Thanks for ur help
    Jock Hamilton
    Jock ;
    Within the 300tdi Bosch Pump there are adjustment that can be made to improve the driveabiliy of your Vehicle ,
    3 Adjustment
    .Eccentric Cone / Diaphram Position
    .Stop Screw
    .Star Wheel adjustment
    before you set out to do any tweeking , Please buy and install a Pyrometer ,don't set about doing any tweeking without being able to monitor how hot things are getting inside your engine ,
    Also if engine is slightly down on Power have you checked following;
    A) Valve Clearances 0.2 mm on intake and EggZost side
    AIR Filter / Fuel Filter replaced etc
    C) Intercooler / Turbo Hoses .
    If you'd like to obtain a Pyrometer go here
    www.thermoguard.com.au
    Free Again Thanks Dan
    Try this from the past some good info in here , and links , the search button is your freind
    injector pump tweaking
    Oct 2007
    JUST NORTH OF COFFS HARBOUR NSW
    Maybe you could replace the exhaust with a 2.5" system strate through i don't know how much power you will gain though
    Or you could upgrade the turbo and intercooler, new airfilter, new injectors etc.
    CHEERS TIM.
    On my Tdi i removed the main muffler and replaced it with a straight thru hot dog muffler , It made a slight difference at spool up
    Sussex Inlet. N.S.W.
    I had gas fitted to my 300tdi. It has a great increase in performance plus around 1000k per tank of diesel. Jim
    Jim VK2MAD
    '17 Isuzu D-Max
    Quote Originally Posted by jx2mad View Post
    Safest way to get more go.......tweaking the pump can lead to disaster for some and if you want to go down that track..get a deiso mech to do it....IMO
    Jock The Rock Guest
    thanks for all your advice fellas
    ill see how the wallet is feeling after the seal is fixed, and perhaps hava look at some things.
    i noticed no one mentioned electric cooling fan kits? or silicone hoses? are they a waste of time?
    im only askin as ive read about them in magazines.
    by the way can i ask how much the conversion set you back?
    Jock
