Results 1 to 4 of 4
Thread: Inline engine saver in 300tdi disco
    Apr 2007
    Newcastle NSW
    Howdy all,
    Well, I have searched and found nought on the details I am chasing, so here goes.
    Has anybody installed an inline "engine saver" low water alarm (ie cut radiator hose and install tube in hose) on a 300tdi Discovery?? What I'm interested in is where they have installed it?
    Common sense says to put it in the top radiator hose, but finding a straight section long enough for it to fit is a bit of a worry! Just after some previous experience on placement of the sensor.
    Thanks in advance everyone.
    Goldey
    Just arrived: 2012 D4 3.0 HSE, the journey begins again ;-).
    Gone: 98 Disco 300tdi Auto, and some extras
    Oct 2007
    Hey Goldey. People have done it on here and I had a look today on mine because I'm doing the same thing.
    I didn't see any spot which stood out either but if I work it out I'll let you know.
    NSW , Pennant Hills
    This is how I done mine , didn't need to be on a flat spot of the hose , actually mine is right on the bend , works a treat , as long as the low coolant sensor is pointing vertically down , will do fine.
    Apr 2007
    Newcastle NSW
    Thks Disco owner
    That's roughly where I was going to put mine, but wasn't sure if the hose would fit after I cut it. Many thanks.
    Goldey
