Results 1 to 8 of 8
Thread: Paint code
    Piggabeen (Tweed Heads)
    Paint code
    hey guys
    Would anyone know the paint code for a white 85 model. I had a mishap with the grinder years ago and that bit on my compliance plate is gone.
    I dont know how many whites there were in 85 but I,m hoping only one.
    Will post photo when Photobucket stops s....ing itself.
    Justin
    Rangier Rover Guest
    I have seen this here before but damn if I can find it I have RR codes here in PDF but not sure what they call white. I had fun with this when doing resto on a 84 PH2. Tony
    Paint code
    Thanks fellas
    Justin
    Maryborough QLD
    Good link, very helpful. I'm planning a respray on the Vog over Christmas (DIY, not pro stuff. It's gonna get scratched and bent up so nothing too flash )
    Thanks, Trav
    r.over Guest
    Every paint batch varies a little and you should not rely on paint codes. You are a lot better off taking something like your petrol filler cover into a paint shop and having the colour computer matched.
    Maryborough QLD
    paint matching
    i've never had a real issue, I find out local Autobarn storte pretty close to the mark and it's hard to tell the difference. I'd probably use a smaller specalised shop if I was to do a full respray (and cheaper too).
    Trav
    Try this link guys
    none metallic colour
    This guy seems to keep his list up to date quite regularly.
    All u need are the last 3 digits & the paint guys will match it.
    Have used this on many customers cars & never had any problems.
