Results 1 to 10 of 23
Thread: Rebuilding a 4cyl
    Rebuilding a 4cyl
    Gday all,
    I am thinking about rebuilding the 4cyl series 3 petrol engine i have lying around in my spares landy. It was running a year ago, but it is in a pretty sad state at the moment as the landy has been out in the weather.
    What sort of cost am i looking at to buy the parts that are usualy required for a rebuild?
    Are there any parts that are hard to find, or cost a small fortune?
    Thanks in advance
    Paul
    WA
    It has been a few years since I have done one (2002/3 was the last), but all parts were/are available, and a full rebuild (rebore, OS pistons, all new bearings, seals, etc, etc) used to set me back $600ish. Usually cost around $200 to get an engine shop to rebuild the head (with hardened valve seats), and about $100 to clean the block and regrind the crank.
    Caboolture
    Thats less than i thought it would be, Wonder if the prices are still similar.
    it cost me <$1K to redo the engine that now resides in Fozzy, did everything but the injectors and the pump....
    However I did all the block work myself as the bores were still good as was the mains journals...
    If you need to do a complete re-alignment and line bore it can get fairly exxy but even all of that including new pots, rods, k lining the valves and converting to stainless seats you should get change out of $2.5k.
    Bearing sizes up to and including 0.030" are easy to obtain. I could not find 0.040" bearings. Good thing I was able to grind my crank to 0.030". I also needed a set of 0.040" rings. These were incredibly expensive. I think they were around $280 in Australia, and around $270 from England. I ended up getting generic rings from JP Pistons for around $160. I needed three compression rings, and you will only need two, so your amount will be less.
    Aaron.
    ok sounds a lot cheaper than I expected. Are there any engine shops that anyone would recommend, or ones that specialize on Rover engines (in Brisbane).
    Paul
    Caboolture
    Damn thats an expensive set of rings. Hope i dont need the 40tho when i go down that road.
    Quote Originally Posted by Mick-Kelly View Post
    I was thinking the same thing
    IF youd like it I have a runner that needs a new set of coolant gear, alternator adn starter, possabley a rear main that you can have if you can tie it into one of the many other runs I may have coming up I can even deliver it...
    Moruya Heads/Sth. Coast, NSW
    Quote Originally Posted by paulthepilot_5 View Post
    Gday all,
    Thanks in advance
    Paul
    Keep an eye out on eBay, I picked up a set of new Diesel Pistons for $60, a set of new Valve Springs for $25, Gasket sets are reasonable, should be able to get a set of rings cheaper than above, $140 to bore standard block to 40 thou over, Regards Frank.
