 Originally Posted by
andrew e
				I cant help you which lines go where, but a TD5 disco pump will also fit your defender, and it is several hundred $ cheaper new. The only slight difference, is that the disco one is about 10mm longer, but it has a spring loaded pickup which just gets pushed up. My sister has been running one in her 110 for a few years now no probs.
Andy
 Andrew, did you have to swap the fuel senders over aswell? (At least you CAN with these pump units )
I've thought about doing this due to the $$$ difference which is completely unjustified but I would be pretty certain the senders would have to be swapped over.
Thanks for the info!
JC
