1995 130 dualcab
stock rear springs, front kings HD
rear bump stop clearance - 145mm
front bump stop clearance - 125mm
235/85R16 on stock 130 rims.
2m to roof of cab.
that enough info?
Steve
Can anyone and everyone please supply me your overall height of your wagon and doublecab (cabin only I can mod tray headboards etc), please advise the tyre size and any suspension lift etc
I need to find out if it's going to fit in the property we might be moving into![]()
1995 130 dualcab
2m to roof of cab.
that enough info?
Steve
1996 130 tdi D/C
265/75 16 wheels and tires
have not checked bump stops but all is "standard"
height to highest point on roof is 2m on the nose.
Hope that helps.
Mal
2001 130 dual cab
Lifted
2.25 meters
No it doesn't fit under a standard garage roler door.
Big red 2.05m (just a touch under)
stock everything suspension and rubber wise.
agreed, it does sound high. 2.250m high would be approx 88.58 inches/12ft4 inches. so i spose it means you got a 9 & 3/4 inch lift, man thats good height!!!!!!!!! any woman would be proud to have a hubby with thatand need a step ladder to get in.
Best forget your imperial conversions philco, just stick with the metrics.
Roger
