Results 1 to 10 of 13
Thread: Mystery Warning Light
    TeZZaP Guest
    Hi guys
    I have just had a warning light come on that is not covered in the Owners Handbook; it looks a little like a baking tray with a wiggle-line in it plus a drip underneath. On my 2003 Defender its under the ABS light and next to the Transmission oil temperature light.
    Its a bit odd that every other symbol is covered in the Owners Handbook except for this one - I can't even guess what its telling me!
    Anyone know what it is from my shabby description above? I'm not sure if I'll be able to get a good enough photo of it to post here. I've done a bit of internet searching but can't find anywhere that list all the warning lights and what they mean...
    Jun 2003
    Launceston, Tasmania
    Oil pressure? oil level?
    1994 Discovery TDi
    2004 Discovery 2 TD5
    2010 Discovery 4 TDV6
    TeZZaP Guest
    Quote Originally Posted by Phoenix View Post
    Not sure, the oil pressure warning light is an 'oil can', and is also mentioned in the owners handbook, the one that I have illuminated is not mentioned in my handbook.
    Is there a separate warning light for oil level? I guess the symbol could be indicative of low oil; the vehicle is not on level ground at the moment (hilly area), so the actual oil level in the vehicle has not been checked yet (its not actually here with me, my wife has called me to let me know this light has come up - I need to decide whether to abandon the car where it is for me to go and work on in location, or get her to drive it home...)
    Ringwood VIC
    Water in the Fuel?? I know some toyotas have a sensor for this.
    TeZZaP Guest
    Quote Originally Posted by 81stubee View Post
    Hmm, could be that as well!
    I'll try for a pic of the symbol...
    TeZZaP Guest
    pic
    Here is a pic, its the one with the 'drip' under it...
    Jul 2003
    Yes it is the water in the fuel filter warning light.
    AFAIK That means either you need drain the fuel filter or the sensor is malfunctioning (short somewhere).
    Mahn England
    Ex 300Tdi Disco:
    Sydney, Northern Beaches
    It is a "water in the fuel" sensor. From memory it sits on the plug that goes into the fuel filter on the rear chassis. It doesn't necessarily mean there is water in your fuel lines, driving through a puddle with water splashing on the fuel filter unit can trigger the warning light. Might be worthwhile just to remove, clean and dry it out and see if the warning light goes off.
    TeZZaP Guest
    Thanks guys - why the hell wouldn't they put that in the bloody handbook!
    Its never come up before, but it is raining today, so maybe some spray has got to it. The vehicles driving OK, so I think I'll risk getting the wife to drive it home and then I'll give it a clean up and see if it goes out...
    Bracken Ridge, Qld
    I would have thought it's like every other warning light... apparently they all mean
    'Contact your Land Rover Authorised Service Centre".
    gone
    1993 Defender 110 ute "Doris"
    1996 Discovery 1
    current
