Page 1 of 5 123 ... LastLast
Results 1 to 10 of 44
Thread: Query on setting up turbo on NA 4BD1
    Hi All,
    long time watcher of the isuzu-landy forum (it was how I discovered them in the 1st place) but haven't had much to contribute to date. Thanks to all for the background as I'm a fan of the set-up.
    I've had a NA4bd1 running in a ratty old 82 range rover for a couple of years now (conversion was done around '92, two owners before me) and I've finally got around to getting it seen to.
    I've found a 93 vogue and the process of moving the engine, 4 speed and a bunch of other bits across and refurbishing anything that's r**ted has started (I'm not doing the work myself).
    Naturally the subject of turbocharging has come up. The general consensus on this forum seems to be - if the engine's in reasonable nick, do it - but don't go too nuts on the boost.
    The bone of contention with the chap doing the work (who's reluctant to turbocharge an old motor to start with - fair enough) is that the NA motor injector pumps cause the engine to smoke like blazes when it's off boost - bad enough to attract the attention of the fun-stoppers.
    There's been no mention on this forum of belching smoke when turboing a NA4bd1. Has anyone had any issues in this regard? or is there a way to set up the turbo/exhaust and fueling to compensate?
    any further info would be greatly appreciated.
    cheers,
    will
    Darwin
    Can't say that mine blazed smoke out the rear at low revs, there was a little under hard acceleration but that was about the extent of it. If it dose it then look at other problems like haveing your injectors cleaned and having the timing checked. And a new air filter dosen't go astry either.
    AFAIK, Isuzu trucks released in Australia with the 4BD1-T, did not have the boost compensator fitted to the injection pump (but some other countries did).
    The purpose of the boost compensator is to reduce fuel/smoke when boost pressure is low.
    Although there are some differences between the injection pump on the NA and turbo engine, the main ones are calibration (disregarding the boost compensator).
    Sounds good to me.
    current thought is for a garret GT2560, which I gather mounts to a standard isuzu turbo manifold (westar quoted $230 new).
    Should these two bolt straight up?
    W
    Kiwiland
    Quote Originally Posted by will@montlaur.com.au View Post
    Sounds good to me.
    W
    If you pick the right turbo, you'll have very little time off-boost and so the smoke won't be a problem.
    I have a JDM engine which has a boost compensator (reduces fueling when there's no boost), I suspect the pumps without boost compensators restrict fuelling based on rpm, this would be the torque plate's influence.
    The GT2560 (basically the new version of the old T28) is a good place to start, but I went even smaller on mine (GT2252 is the new equivalent of my T25).
    It won't bolt straight up, but I have an adapter design which will make it fit. See this thread http://www.aulro.com/afvb/isuzu-land...o-install.html for pictures, PM me if you'd like a copy of the drawings.
    Quote Originally Posted by Dougal View Post
    Thanks Dougal,
    I'm trying to stick to the 'keep it simple' principal given I'm not doing the work myself, so off the shelf would be preferred.
    Am I correct in assuming that any turbo from the GT25 family will mount straight up to a stock turbo manifold? 2nd assumption being GT22 or smaller won't mount straight up?
    If that's the case any reduction in turbine size takes me outside the "mount straight up" requirement; ie into the GT22 family. A GT2554 will provide a smaller compressor but I don't see that providing any benefit in making boost at the lowest revs possible. (correct me if I'm wrong here)
    I know I'm just fishing for an answer I want to hear but if a GT2560 meets my needs, ie;
    a) mounts straight up to a stock manifold
    b) wastegated, ball bearing & water cooled
    c) quick spool (I'll keep the exhaust as large as possible)
    I think I'll probably stick with it. What do you think?
    W
    WA
    Thanks Dougal,
    W
    The factory manifold has a T3 flange. Very few turbos of the correct size have a T3 flange. AFAIK all the turbos you mentioned above have a T2 flange, which is why an adaptor is needed.
    The turbo I fitted (in the thread Dougal linked) is the same as a GT2560R except that it has journal bearings. IMHO, you wouldn't want to go smaller than a T25, and it won't help with the flange issue.
    Water cooling offers no benefits, and some disadvantages in a diesel. Have a look at the turboglide website for the reasons. Many people (Dougal and myself included, run water cooled turbos with the water lines disconnected/blanked.
    If you are paying someone to do the job, the turboglide kit may be a good way to go.
    Yinnar South, Vic
    I don;t run the water cooling either
    Turboglide will do a full kit for you
    Mine smokes off boost and sharp throttle openings in low range, but you don;t need to fuel it up that much
    excellent. thanks heaps guys.
    I'll give turboglide a call on Monday and see how I go.
    W
    Brisbane, Queensland
    I fitted a GT2560 (GT28R ?) to mine on a genuine Isuzu top mount T2 manifold. It spools up fast, engine doesn't smoke, so I don't think it is over fueling. As with Ben my compressor had to be rotated requiring some modification to the actuator arm. I had mine fitted by a Brisbane turbo specialist with a long and good reputation. The result was excellent but cost a lot more than Ben's. Two things the installer insisted on was an over boost safety valve and new injectors. I went 3" mandrell pipe with a lukey muffler.
    L322 tdv8 poverty pack - wow
    Track Trailer ARN 200-117
    REMLR # 137
