The only ones I've seen come out of the UK for over ₤150 for a complete set so I've never looked any further. Can't recall the brand name.
 Wizard
						Wizard
						Does anyone know of a supplier making complete LED replacement light assemblies for 110's, 90's etc?
I'm looking for entire assemblies which preferably fit into/over the existing panel holes yet which look similar to the originals.
I'm interested in these for a trailer I am planning, but have yet to find any.
and the pommy ones dont meet the adr's or didnt last i heard of them.
2007 Discovery 3 SE7 TDV6 2.7
2012 SZ Territory TX 2.7 TDCi
Gday i know of Brightlights auto parts(Paul), i have bought several lights from his online shop and also his Ebay store. I have checked his store and he doesnt have any lights that i can see would suite but if you contacted him and enquired as to if he knows of a replacement to be or can be used. Maybe if you arranged a option for other AULRO members to add to an order you may end up with a good purchase.
Could be worth a try.
http://www.brightlightautoparts.com/
Here's a complete kit of all 8 lamps from a UK company, but not cheap:
CLICK HERE
Also, they do just the rear stop/tail lamps:
CLICK HERE
Have you thought about putting those LED replacement bulbs in your standard lamp holders instead?
Jon
use your existing assy's and just get led globes. can get them in all formats.
I got mine from here
 Wizard
						Wizard
						I've tried that but not the best option for a couple of reasons:
-still leaves the issue of leaky, corroded terminal connections at the base of the bulb which are marginal even when new
- the replacment LED brake light globes arent as bright as an incandescant filament (not enough contrast between tail light and brake light) -unless the quality has improved since I bought some a couple of years ago
- the lenses are still easy to break - a good LED assembly should be resin filled and have polycarbonate lenses which are very tough.
The ones I use on my boat trailer are just about indestructable.
I could bolt these on the back of the 110 but it wouldnt look right (understatement)
Sounds like there is a market for some reasonably priced assemblies.....
adr approved and waterproof $40 at autobarn ten times brighter and yes they are legal
http://i248.photobucket.com/albums/g...52008297-1.jpg
