Results 1 to 10 of 36
Thread: Removing hub nuts...
    Redland Bay QLD
    Gday all,
    My old man has decided to replace wheel bearings or something on the '98 d1. The problem now is that the hub nut is a little over 50mm, and have no idea where to get a socket for it.
    Where do people get these sockets from? Or what can be improvised?
    Cheers!
    PS. Im in Brisbane...
    Cambewarra, NSW
    The tool for these nuts is a large "tube spanner" readily available from most of the parts suppliers for around $30. Try Karcraft or Rovercraft (or similar up your way), both are mentioned numerous times in this forum.
    Redland Bay QLD
    yeah ok, I was hoping to sort something today... lol
    Cheers!
    go over to fwd Fairfield rd Yerongpilly, and buy the over size socket for the job. The bearings have to be torqued up and the done again at a low torque anyway. I bought some for my series LR 20 years ago - still same size on my disco.
    52mm, you can get them from ARB (54mm for tojos) Mr automotives, Supercheap sometimes carries them
    blackwoods, truck shops and some plumbing places.
    if you want to come out to the switch you can borrow mine.
    Feb 2005
    try and get a tube spanner $10-$15 max
    if you are anywhere near pinkenba you can grab mine if you are quick
    Redland Bay QLD
    Thanks for the replies!
    It seems he is happy to work on other parts of the car today. Phoned BMI and ordered one.
    I tried calling all the local places and it was amazing, noone had them.
    Sorry Blknight, I am close to 2 hours from your place but thanks for the offer!
    cheers!
    Quote Originally Posted by beforethevision View Post
    Gday all,
    Cheers!
    Just a quick bit of info for you on tightening the nuts
    Attached Files Attached Files
    a big pair of multigrips works fine if you havn't got a socket.
    Safe Travels
    harry
    Kingston, Tassie, OZ.
    Quote Originally Posted by harry View Post
    These bearing adjuster/ locknuts nuts hold your wheel hub to your vehicle.
    If they come loose or come apart, the only thing holding the hub assembly on is your brake caliper.
    Not to mention that you can loose braking performance while the hub is 'coming off'.
    Please buy the correct tool for the job, especially one as important as this.
    JC
