Results 1 to 10 of 16
Thread: Best model/series
    cloudy Guest
    Best model/series
    I'm a newby here so i hope you'll forgive me if I'm raking over old coals, but I would love your collective opinion on which model you think were the most durable.
    I have a disabled wife (Wheelchair) & she felt much better in an F100 than our present wagon.
    I've been considering buying an RR for a while now, & probably will after xmas.
    I'm no spring chicken & I've had a string of pommy cars, the last one being a '72 XJ6 that I loved.
    It won't be used for off road. I doubt I'll be able to afford anything above a 95 model.
    I've known a couple of blokes that have had them & they couldn't speak highly enough about them, but when you look at the price of a Ford Bronco with a heap of K's up & compare the prices, makes me think the car world has gone mad.
    Any advice would be appreciated.
    g'day cloudy
    late 80's RR classic would be my pick mate. peanuts to buy, peanuts to maintain. apart from the efi everything else is mechanical, ergo fixable. even efi is cheap to service. avoid later car's air suspension and anti lock brakes.
    if you could live with things like the jag's a.e.d. then an RRC will be a doddle. like jag you get undatable design, crashworthiness, creature comforts and you can tow a trailer without b^ggering up your suspension. plenty of room for the g.l.w.'s chariot in the back too.
    Maryborough QLD
    As above. The earlier ones with the LT230 are my pick, the Borg-Warner Viscous coupling transfer are okay but can be costly to repair but if you have no intentions of going off-road they're fine.
    Also look at the 90-91 3.9's which are a step better and well appointed as well.
    The earlier EFI system (pre 3.9) are a bloody PIA and need to be maintained to a degree or they'll be troublesome. They all seem to overfuel on cold startup and flood badly (the 87 Hi-line did as well as the 88 Rangie I have currently) but once warm they run as they should. Hi-Lines are better appointed but I prefer the 'dunga spec' basic model for the lack of frills (and less crap to go wrong such as electric windows and mirrors, etc..).
    Don't pay too much, anything over $3K for a late 80's Rangie is too much unless it's mint. Plenty of cheaper ones going around on e-bay but you need to do your homework and most are sold unreg and could cost you a small fortune to get back up to roadworthy state unless you do the work yourself. I paid $850 for my 88 Rangie, spent $600 (power steer box and new front seats, the old one had a busted frame and had to buy a pair from a 91 Vogue so they would match) but still had it on road for less than $1500 before rego. Not bad value IMO.
    Anyway, good luck with it.
    Trav
    Rangier Rover Guest
    1986 to 1988 Range Rover auto with LT 230 (Center diff lock) The early efi are quite robust and if some one can use a multi meter should not cause much grief.
    Cheers Tony
    cloudy Guest
    Taking it a step further, is there a lot of difference (Apart from appearance) between the Land rover (Discovery, Freelander) Forget diesels. Don't like them.
    St Helena,Melbourne
    4.28 MB
    Quote Originally Posted by cloudy View Post
    The 89-99 series 1 discovery is built on a classic rangie chassis and uses pretty much the same mechanicals (although updated), i would look at disco's as well as classic rangies are getting on and will require constant maintainance where as a series 1 disco up to 99 is basically the same vehicle but newer and a little simpler as far as elctronics and features go and you will get a newer car for roughly the same price.
    I love the classic rangies but in your situation a newer vehicle may suit you better.
    2004 Jayco Freedom tin tent
    1998 Triumph Daytona T595
    1974 VW Kombi bus
    1958 Holden FC special sedan
    cloudy Guest
    "series 1 disco up to 99 is basically the same vehicle but newer and a little simpler as far as elctronics and features go and you will get a newer car for roughly the same price.
    I love the classic rangies but in your situation a newer vehicle may suit you better."
    That's pretty much the way I'm thinking loanrangie.
    I had a look at a '95 Ranger & was blown away by the finish & appointments, but was not encouraged by the comments & experiences some have had here.
    It reminded me of what steered me away from an XJS Jag. "Can't beat them when they're going but the sickness is contagious when they're not"
    r.over Guest
    Up to 1995, even in the top model Vogue SE, there is not a lot that can't be fixed reasonably cheaply. Many have already had the air suspension removed. The EFI hot wire system is pretty reliable. If the ABS packs up you can convert it back to non-ABS at not much cost as long as you do the work yourself.
    If you are going to buy any Rangie classic, find one that someone has got rid of because they got sick of spending money on it. That way you are likely to get one with the many wear items replaced.
    perceived wisdom is that rangies were built UP to their price whereas discos (all points north of the chassis and drivetrain) were built DOWN to their price. they are ALL old now but all the negative things you've read about rangies here are generally about the parts common to both.
    to further use the jag analogy, think series 1 vs series 2 XJ's. i know which one i'd rather have........(or rather HAD , '73 XJ12)
    series 2's (contemporaries of the XJ-S) were subject to bloat, cost-cutting and built by a disaffected workforce. it wasn't 'til '83 that the quality started to return.
    cloudy Guest
    A bit clearer
    This is good information fella's, thanks.
    I getting the impression that as an owner of a 95 Fairmont wagon with all the bells & whistles, that I'm not in for any more grief than I'm getting, prolly to an even lesser extent maybe.
    The Falcons are notorious for blowing head gaskets & a "bad un" can make your eyes continuously water.
    I can't complain about mine though. If the numbers on the odometer didn't read 400K's you'ld believe it was just run in, the way it drives.
    But it seems to me that these computer generated problems are an "across the board" thing.
    A mate of mine traded his upmarket Mercedes RV on the equally upmarket Honda RV because the bloody drivers side window wouldn't seal.
    He been to the dealer 3 times about it. On the 3rd occasion, when he got it back with all the re-assurances that it was fixed, he put it through the automated car wash on the way home because the workshop gave it back to him with hand marks on the bonnet & door.
    He arrived back at the dealers managers office looking like a flood victim.
    A distinguished successful businessman can look just like a wet grizzly when they're both wounded.
    After much grovelling, the manager offered to drive him home.
    "That won't work, I think I'll faking kill you, & prolly the both of us on the way"
    He now drives a Lexus, & so far so good.
    So really, it seems that the RR's more unique problems are with the suspension & ABS mainly. Would that be about right?
