Results 1 to 10 of 13
Thread: Range Rover Classic headlight upgrade
    Jun 2008
    I have a 1985 Range Rover Classic and the headlights are really annoying me..... I reckon I could hold a dolphin torch out the window and illuminate the road better.
    Are there any bulb upgrades worth looking into? Or are there any drivinglights on the market I can fit on the front bar that can be used all the time at night.
    The rangie came with that plastic front spoiler with a pair or rectangular hella lights in it, I ripped the whole thing off, should I just mount those hella lights on the front bar?
    Douglas Park, NSW
    I'm not sure if the 85 had sealed beams or H4s.
    If you have H4s already, then the light output should be OK.
    Check the voltage at the lights: if less than battery voltage while running, then fit relays & maybe upgrade the wiring too.
    Bigger H4 globes are an option too but check the basics first.
    Then there's HID if you want to get serious .
    Avoca Beach
    If you want to upgrade your headlights you MUST either build a loom which feeds the power to the headlights straight form the battery , or buy a loom from vendors such as Piranha. This routes the power through a relay which is switched by the headlight switch.
    If you do not you will fry the switch very quickly.
    The loom itself with no other changes will probably make quite a difference.
    I have had 100/90 bulbs in my headlights and IPF replacement reflectors with a loom for many years and they are quite bright even without spots.
    I would not use the Hellas as I have found them not very good, as they have a very shallow beam so need to be adjusted very accurately. Even cheap 120MM rounds from Supacheap are probably better, but again you must feed them from battery power via a loom, with the existing switch triggering a relay.
    Regards Philip A
    The other problem with early RRs is the headlight mounting system. It's not that precise in beam alignment.
    I fitted a later grille and the later headlight buckets. See Range Rover Grille Conversion
    NSW , Pennant Hills
    Regards Philip A
    Bashir;
    PM drivesafe in here and he has headlight and driving light wiring Kit upgrades
    index7
    I bought a set of Wipac freeform reflectors off fleabay, however the seller was a bit of a knob and never got back to me regarding the order. Do a search on the number in the link.
    Wipac do have an intl purchase site, however Australia isnt in the list, so I couldnt get them direct.
    I ended up buying two sets, "just in case"!!
    Headlamps
    Hawthorn, Victoria
    Cool
    I've done an IPF loom and globe upgrade kit on my S1 Disco and my Defender and it makes a huuuuge difference - well worth the money, I hardly need my driving lights now!
    Maryborough QLD
    Pm drivesafe on the forum, he sells a headlight upgtade and cheaper than the IPF ones i think. I had this kit on my old Rangie and it was great. I would get another one but had a headlight upgrade done already
    The old Rangie headlights are crap IMO. I use the el-cheapo sealed beam units that supercheap sell, for less than $10 each you can't go wrong. I had the 'blue light' bling crap but after a water crossing or two (yes it does rain in QLD although not often ) they got hammerd so back to the dunga sealed beam unit for me
    Trav
    Adelaide - Torrens Park
    I have upgraded the headlights in my '87 Rangie with IPF H4 inserts. Then I fitted genuine Subaru (Phillips I think) upgraded globes. THey are still 55/60 watts, but give a much whiter light.
    Medowie NSW
    I'm about to upgrade my rangie with ipf lenses and fatboy globes and a wiring harness upgrade.........not cheap but very effective
