Results 1 to 10 of 13
Thread: Defender / County Rear Seats
    Dayboro, Qld
    I'm assuming that the Defender rear seat is a straight swap to replace a County rear seat ??? and that it's a bit more comfortable
    Next question, does anybody have a spare for sale ?? I put an ad in markets but only had 3 views !! Condition not too important
    You should post a link to the ad in Marketplace Alerts-
    Marketplace Alerts - Australian Land Rover Owners
    Ads don't register as posts, so those that use the site via New Posts, or Quick Links > Today's Posts don't get to see them.
    Can't help with the rest.
    Simon
    May 2008
    cairns
    defender rear seats suck keep the county ones
    Sep 2006
    Northern Beaches
    I agree, the Defender rear seats are pretty ordinary for anyone older than 10. Great for kids though as they see way more than in almost anything else.
    Jeff
    The Def rear seat (actually MY87 One Ten onwards) is a 33/66 splitfold and sits closer to the front seats so leg room is reduced but of course load space in the rear is up slightly. I found the locking anchorage for the back rest very flimsy and while it will go into an earlier One Ten some small brackets/fixings/holes may be needed.
    JDNSW's Avatar
    Quote Originally Posted by isuzubob View Post
    ...... sits closer to the front seats so leg room is reduced but of course load space in the rear is up slightly. .....
    I have never actually measured them, but my impression is that the later seat is in the same place, but appears to be closer to the front seats because the seat is deeper.
    Oct 2006
    The Vines WA
    Also, don't the rear seat passengers sit higher up in a Defender? In a County they can see out the door window... in Defenders it's more like looking out the alpine window?
    Dayboro, Qld
    Thanks for all your comments, I just assumed that the defender rear seat would be a better and more comfortable option. Maybe I'll have a look at one in situ before changing over.
    Sep 2006
    Northern Beaches
    Quote Originally Posted by LoveMyV8County View Post
    Wouldn't that depend on how tall you are? I end up between, looking at the roof, too tall for the door window but not tall enough for the alpine window.
    Jeff
    May 2008
    another option is to use front set out of a disco they have the frame to raise the seat up the only problem may be the width to put three in.
    The other option would be to put only two in and a storage box in the middle if you only require to seat for kids.
    Kev
