Thread: RTC Steering Dampener
    Tuross Head NSW
    Hi All,
    Ive done the searches re Tough Dog RTC dampeners and seems to be a mixed response. I dont mind experimenting a bit BUT are they easy enough to put on? a D2a, never put a steering dampener on before. It seems they need some adjustment following fitting? Thanks.
    Steve
    2016 SDV6 SE Graphite "Pearl"
    2003 td5-Auto--- sold
    1992-200tdi Man---gone.
    2 bolts, one at each end, 15 minute job if you take your time. What can make it difficult is when you take off a very overdue for replacement unit that has elongated the mounting holes.
    Personally I wouldn't use an RTC damper. Don't know what TD dampers are like, wouldn't touch their shocks as I've seen too many fail. Admittedly they are good on warranty replacement, but its a bit of an inconvenience for the owner. I prefer the Bilstien dampers, others will say different. Its an individual thing.
    Karratha WA
    Top Dog RTC Damper is good
    Hi,
    I have been running a Top Dog RTC damper for 3 years now. I found that when towing my 2,500 kg van that it took the shimmy out of the front end.
    You just need to tweak them to sit at centre. A few drives around the block works it out.
    Quote Originally Posted by BradM View Post
    Hi,
    Same as Brad 3 yrs not a drama..including the shocks, heresay is never as good as actual experiance
    Zute Guest
    I have a RTC TDog on my Zook, and I must say it made little differance. But it does look very "Bling".
