Results 1 to 10 of 15
Thread: Uh Oh! 'Shudder' while accelerating.
    Frankston, Melbourne
    Hi folks.
    My vehicle has developed, what can be best described as, a shudder under load.
    I suspect drive line rather wheels/tyres/balance etc.
    Only started today and is more aggressive on inclines.
    The vibration comes-up through the steering wheel and then the whole vehicle joins in.
    I hope it's prop. shaft uni's or similar. Probably fronts?
    Gear box shifts fine. Fluid levels are ok (but, aged). Motor runs sweetly.
    Any ideas?
    Nov 2008
    dose it get worse the faster you go, if the engine still runs fine when it hapends, could be engine mounts, could be the harmonic balencer has fallen off, or if its realy bad could be somthing around the hand brake or props, whats it like on run down
    mike 90 RR Guest
    Check for broken engine mounts ....
    Mike
    Quote Originally Posted by stig0000 View Post
    I reckon the problem is around the handbrake area!
    Speed doesn't seem to matter, more load!
    Check the harmonic b. by hand, seems ok!
    Will check engine mounts! thanks!
    Run down is smooth as the proverbial.
    Definetly a load issue!
    Hope it's props. and not transfer or gearbox!
    mike 90 RR Guest
    Quote Originally Posted by discomuzz View Post
    Check the mounts first ... You don't want them to break
    Front prop shaft, go check, quick, before it rips out your transfer case.
    Tamborine Mountain
    DC joint uni's on front prop shaft? plenty of threads about this
    in the wild New England, NSW
    drive plate (if it's an auto)
    Quote Originally Posted by mike 90 RR View Post
    Done! All seem ok. Thanks.
    Quote Originally Posted by Nicky View Post
    The shaft has about 5mm of rotational play. No end play and no lateral play.
    But! The transfer case sounds like it has no oil in it and clunks when the prop. shaft is twisted to and fro. by hand.
    I suspect you are onto something.
    But what?
