Results 1 to 10 of 21
Thread: 300Tdi coolant reservoirs
    Alice Springs
    I recently replaced the coolant reservoir on my 300Tdi for the second time. I hadn't had to top up the coolant but I did notice it just starting to weep along the join. I only got four years life out of the old one which is not too inspiring. You would think that somebody somewhere would have come up with an aftermarket one that actually lasts.
    Bigmark Guest
    There is someone on Ebay selling stainless steel or aluminium ones for around $300- a lot of money i know but would last 1000 years.
    The black plastic ones have a bad reputation. By all accounts the white plastic replacements have overcome the problem of seam failure.
    Kingston, Tassie, OZ.
    The white plastic ones are better, I have never had to replace one of them yet.
    Some I have fitted quite a few years and KM's ago too.
    JC
    in the wild New England, NSW
    our white plastic replacement tanks are ok (so far that is) .... fingers crossed
    at least the weep on the black tanks gave us a little warning....
    mcrover Guest
    Check your cap is venting, I have come across 2 split tanks on the same Disco that were caused by the cap nopt venting under pressure.
    30PSI is the max I think from memory.
    NSW far north coast
    Quote Originally Posted by mcrover View Post
    15 psi.
    I've had problems with aftermarket ones not sealing.
    The genuine caps (German) are cheap from places like the company in Sydney that cannot be named. Pt # NTC7161 (just happened to have the invoice sitting here )
    Haven't had a problem yet from the genuine white tank I fitted a few years back either.
    Free Again Thanks Dan
    240 k,s and my black plastic one is still going strong
    While your changing you black plastic tank because it might split change the head gasket cause that might blow and everything else on the car that might blow or fail
    Quote Originally Posted by rangieman View Post
    JC
    JC
    I was hoping you would see the lighter side in that jc
