Results 1 to 10 of 15
Thread: spyware guard 2008
    Ferntree Gully VIC
    spyware guard 2008
    i need help to remove this bloody thing
    suggestion most welcomed please
    by the way i'm not a big PC guru either
    130's rule
    Central Queensland
    step 1: find out who installed it/clicked "ok" so it could install itself
    step 2: torture them to death
    step 3: find a geek IRL who can help
    SA, Newton
    down load superantispyware ( google it) just get the free one.
    that should do it, oh and do the updates
    Ferntree Gully VIC
    Quote Originally Posted by clean32 View Post
    if already done that
    but no go either have also tried heaps of other free versions.......
    130's rule
    Ferntree Gully VIC
    Quote Originally Posted by Sprint View Post
    steps 1-2 covered and tortured for
    won't mention beings for sake of criminal offenses ...........
    130's rule
    Try Prevx
    Prevx - Customer and Network Security and Breach Management
    It will do one round of free scan and fix, then you have to pay.
    Good at removing difficult stuff.
    Simon
    Try Malwarebytes' Anti-malware.
    Last week I had Windows Anti Virus 2009 come up and even Spybot would not remove it.
    Malwarebytes found and removed not only this one but about seven other low threats.
    Ferntree Gully VIC
    Quote Originally Posted by feral View Post
    seems the wife has already tried that one as well
    130's rule
    Given that I'm a mac person and don't generally have to worry about all this.... didn't Microsoft release a free anti-spyware? Did it work? I would have thought the software supplier should have been able to do that properly... ?
     2005 Defender 110 
    yep microsoft released a free anti bad person kit of software but it leaked like a sieve, used more memory than half the other crud they write and did things like
    this file is bad, do you want to delete it?Yes
    Are you sure you want to delete it?Yes
    are you sure that you just pushed the correct button?Yes
    ok I just need to confirm that the last 3 times you pressed yes wasnt just a case of you having an epileptic fit while holding the mouse perfectly still over then yes button but hammering the left mouse button? Yes
    are you sure your not having a fit? Yes
    do you really want to delete this nasty bit of software that may cause your system to slow down, hang, or operate eratically? Yes
    are you sure your not trying to delete the operating system? Yes
    Are you sick of all the safety check questions? Yes
    are you the system administrator? Yes
    do you have sufficient access rights to delete the file? Yes
    OK one last time Are you sure that your sure that you pushed the correct button and aren't having some kind of miracle siezure causing you to inadvertantly click yes and that you actually want to delete the potentialy harmfull file that you have established isnt the operating system itself no longer want to answer these annoying check questions and are the system administrator with sufficient access rights to delete the file? Yes
    This potentially harmful file has ingrained itself into the operating system and your system will need to reboot forgeting to delete it on startup please re-install windows on a freshly formated hard drive. As part of the roll back system this file has created multiple backups of itself so forcing the computer to boot to a DOS Prompt (yes we still have DOS Windows is still just a pretty front end) and deleting it will only work untill you restart the Windows GUI
    and
    ERROR You have just moved your mouse, Windows needs to restart to effect your changes
