Results 1 to 3 of 3
Thread: Clutch Pedal Pressure.
    Far South Coast NSW & Cambewarra NSW
    Just "up dated" the 97 Defender 130 to an 01 Defender 130. The clutch pedal effort is a lot greater with the td5 as compared to that of the tdi.
    Is this normal?...............Pat
    seems to be the average consensus
    Adelaide - Torrens Park
    When I was in Coffs Harbour I pressed the clutch pedal on a 300 Tdi Defender.
    It was so light that it felt like a Japanese car! The pedal box had been pulled apart, cleaned and lubed after the clutch pedal used to stick down.
    Perhaps a preoperly lubricated pivot is all that is required.
