Results 1 to 10 of 18
Thread: Twin turbo intercooled Rover 3.5V8
    99.87 MB
    Just thought that some of you may be interested in a build which is taking place on Outerlimits4x4.
    The build has nothing to do with me.
    Its a Rover 3.5 that is being used in a comp Toyota Landcruiser run Mog axles and 44" tyres which is being built in Queensland.
    The motor is a 3.5 which I think may have been converted from 2x carby to EFI. Its had a custom set of exhaust manifolds up to a turbo on each bank above the heads. These feed into a common air/water intercooler which then ats as the plenum over the inlet trumpets.
    Outer Limits 4x4 Board :: Log in
    Sump mod to suit front prop for mogs
    Slunnie
    May 2008
    cairns
    more more more .a rover engine in a toyota. cant wait to see the dyno figures
    Oct 2007
    JUST NORTH OF COFFS HARBOUR NSW
    Thats my dream one day, a twin turbod rover v8 supercharged
    poor little V8 why don't they just 440 Hemi the sucker and be done with it.
    $20k crate motor with 700hp
    Oct 2008
    Quote Originally Posted by DirtyDawg View Post
    weight??
    99.87 MB
    and also $20k + all of the other stuff like transmissions etc. This one looks like its a pair of Supra or something turbos and some good ability in fabrication.
    Slunnie
    Rangier Rover Guest
    Why a 3.5 Hope it's a stiff block. Likely not a X bolt mains.
    I would think a X bolt 4 ltr or 4.6 be a good donor for this one.
    I like the intercooler. That setup could work under my eaton M90. With a 2.5" body lift it may fit
    Tony
    99.87 MB
    I think that was just the motor he had in it.
    Slunnie
    Rangier Rover Guest
    Very neat for a custom job anyway. I'd say it will get a reputation once out there. I'm not sure what it may be though
    Tony
    mike 90 RR Guest
    Quote Originally Posted by long stroke View Post
    You left out the Nos kit
