Results 1 to 6 of 6
Thread: Fed up
    Aug 2008
    Deception Bay
    Fed up
    Hi to all, just a quickone, is there anyone on the northside of Brisbane who can tune a 3.5 carby motor? Im oly on a pension and cant afford to go to M R automotive or anyone else because of the cost and cant afford to keep running my pride and joy. I know, a catch 22 situation but can someone please help? Thanks, Bob H
    Safety Bay
    Turn the dizzy slowly until the exhaust goes off song then slowly turn back till it runs even,wind the mixture screw in until it goes off tune then feed fuel back on until it idles smooth again.That will get you out of trouble,saying that they are no different to any engine of there vintage so any mechanic could tune it for you in no time.Are the leads plugs in good nick?,they don't like old leads. Pat
    Aug 2008
    Deception Bay
    Thanks Pat, but this beast still has the twincarbys so its a bit harder than a single carb.
    Safety Bay
    The best thing for tuning twins is a tube fed down the venturi of each carb in turn and the other end in your ear!!,tune them till they both sound the same,sounds funny but it works. Pat
    Apr 2002
    Bellara 4507
    32.43 MB
    this might help
    Attached Files Attached Files
    2007 Discovery 3 SE7 TDV6 2.7
    2012 SZ Territory TX 2.7 TDCi
    Garfield, Victoria
    Quote Originally Posted by PAT303 View Post
    A bit confusing, as in your previous post you were talking about timing & mixture, and here you are talking about the throttle butterflies!
    In any case, the ignition is probably more important as a starting point. If it is conventional ignition, I would be checking plugs, points, leads, timing, and the distributor vacuum advance before getting to the carbies.
    Lionel
