Not strictly true. If the oils gone as far as the ECU then its bad karma all round. The best way to check if this is the issue is to unplug the injector harness at the front driver's side of the engine and check that plug. If there's oil in the injector loom causing an issue it will be visible there. If its real bad, then check back at the ECU.
The M+S flashing, first thing to do is check the harness on the passenger's side of the transmission and give it a good clean up.
