Results 1 to 6 of 6
Thread: Overdrive removal bits
    Northern Beaches Sydney NSW
    hi All,
    Wanting to remove an old overdrive unit not sure whether Fairey or not from my s1 model 1955. Problem is i dont have the replacement gear and plate. where can i source a cheap s1 bits so that i can remove the o/drive. is it easy to remove and restore to original spec. is it just the gear and plate that i need. any help appreciated thx
    Bundaberg Qld.
    If it is the same plate and gear as in a S2 then they should be easy to come by.
    84' 120" ute - 3.9 isuzu.
    Not sure
    Thanks but not sure whether they are the same as in a s2. can anyone answer that one. are the gears and plates similar in a s1 55 model to a s2 when removal of the overdrive is involved. thanks
    rear plate
    Hi
    If you want a plate and bearing
    can do
    what i would like is the over drive
    send me a PM
    ian
    darwin, nt
    Pretty much all 1s, 2s, 2as, and 3s are the same, excepting of course those fitted with all-helical-cut transfers and Stage one V8s. Not sure about very early 80" though - I know some of them had different diffs but not sure what else.
    Dan.
    69 2A 88" pet4, 74 3 109" pet4, 68 2B FC pet6.
    JDNSW's Avatar
    You need a rear plate and bearing, a transfer case input gear and a new lock washer and a new gasket. (doesn't matter what brand overdrive)
    The parts are the same for any Series Landrover except Stage 1 (not sure about the all helical gearbox in the 2b and One Ton, but I think they are the same even for them, as they are designed to fit the same PTO).
    These bits should be readily available from anyone who has wrecked a Series Landrover, (except for the new bits) as apart form this change they would be rarely required.
    You also need to get or make or borrow a spanner to fit the nut on the end of the gearbox shaft - I made one without a great deal of trouble. At a pinch you can probably get by using a brass drift, but it is poor workshop practice.
