Results 1 to 9 of 9
Thread: 1.5v Rechargable Batteries
    I have a couple of small gadgets that run on 1.5v AA batteries - alkaline type.
    I want to put in rechargables but most are NiMh which are only 1.2v which is the same voltage that a 1.5 alkaline is when it is just about dead - as a result some of my appliances (digtaphone - model helicopter) will not work properly as the voltage is too low.
    I went to Jaycar and Dick Smith this morning (battery world were closed) to get the good old NiCad batterys which are 1.5v - guess what NiCads are no longer carried.
    Any ideas on where else might still carry NiCads - I appreciate they are old technology but they can be managed.
    Bunnings?
    2024 RRS on the road
    2011 D4 3.0 in the drive way
    1999 D2 V8, in heaven
    1984 RRC, in hell
    Try here: Servaas Products very good to deal with and knows about what he's selling, so if in doubt give him a call.
    Apr 2007
    Prospect SA
    Hmm
    I always thought that nicad & nimh were all 1.2v
    Interesting, I am pretty sure they are working on lipo fpr AA's now but how long is anyones guess.
    Quote Originally Posted by big guy View Post
    Hmm
    I have some very old c size nicad and these are stamped 1.5v but all the newer ones are 1.2v. Looks like I might be out of luck and have to continue to use non-rechargable batteries.
    Apr 2007
    Prospect SA
    There are whats called hump packs available for nimhs, they contain 5 cells to make up to 6v.
    I find that I can still use them for ordinary applications and just realise to change and charge more often than standard alkalines.
    what you have to watch I guess is the voltage drop under load and it may just come under voltage cut-off and you loose all control from heli or whatever its used for.
    Jun 2003
    Launceston, Tasmania
    Have you checked the venom and other rechargable batteries fro RC vehicles for ther voltages?
    I sould suggest sub C cells, but they aren't 1.5v either.
    1994 Discovery TDi
    2004 Discovery 2 TD5
    2010 Discovery 4 TDV6
    St Helena,Melbourne
    4.28 MB
    I use varta re-chargables in AA and AAA size, good german made batteries and quick chargers - helps when i get them cheap thru work .
    2004 Jayco Freedom tin tent
    1998 Triumph Daytona T595
    1974 VW Kombi bus
    1958 Holden FC special sedan
    But are they 1.2v or 1.5v? It would seem there are no modern 1.5v AA or AAA rechargeable batteries .
    Thanks to everyone for the comments - 1.2v work OK on most things but do not work in my voice recorder when connected to my computer - I will keep a set of 1.5v alkaline batteries for this function.
